Alternator time
mavada
Re: Alternator time
Post by mavada » Tue Jan 24, 2017 10:01 pm
Being euforic getting the bastard out, i forgot which connection to use, 1 or 2...think it was 1
Apart from that, the number on the new regulator is BR14 MO F 00M 144 146...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Ajc
Re: Alternator time
Post by Ajc » Tue Jan 24, 2017 10:06 pm
I would suggest 1 as 2 doesn't have the cable cutout , plus doesn't look as of it has a thread sticking out of it.
Cheers Al
bilko1
Re: Alternator time
Post by bilko1 » Wed Jan 25, 2017 9:15 am
2 holds the reg pack on, 1 is the output. I changed one last week on a golf diesel looks exactly the same. The small Phillips head screws were very tight but I was changing it in situ.
mavada
Re: Alternator time
Post by mavada » Wed Jan 25, 2017 9:49 am
Ok thanks guys, its going in back today.
While im at it, doing an oilchange plus filter to...
Id like to do the oilchange with warm engine but its on jackstands for days now...
Yellow Koni's
mavada
Re: Alternator time
Post by mavada » Wed Jan 25, 2017 10:05 am
By the way, i pushed the bush shown in the pic a bit so it Will fit more easily...
Yellow Koni's
mavada
Re: Alternator time
Post by mavada » Wed Jan 25, 2017 1:05 pm
Old oil out, pretty Black, smells like petrol....
Yellow Koni's
mavada
Re: Alternator time
Post by mavada » Wed Jan 25, 2017 1:14 pm
2 pretty bad rusted bold here, Can i just replace them with New ones or Will it be a risk regarding the gasked/start an oil leak? .....
Yellow Koni's
Re: Alternator time
Post by Shoppinit » Wed Jan 25, 2017 1:19 pm
I would change them one by one. And torque the new ones up correctly.
simonpoulton
Re: Alternator time
Post by simonpoulton » Wed Jan 25, 2017 4:36 pm
Mavada, how are your oil cooler pipes looking (whilst you are around that area)? Trace them back to the front cooler as mine were corroded.
Past: R56 Mini Cooper S
mavada
Re: Alternator time
Post by mavada » Wed Jan 25, 2017 6:35 pm
Yes theyre pretty bad corroded, especially the part from flexible to connection
Yellow Koni's
mavada
Re: Alternator time
Post by mavada » Thu Jan 26, 2017 9:38 am
Some more questions regarding oil.
Do i have to fill the New oil filter for 2/3 with New oil before installing it?
Do i have to replace to old gasket/ring from the engineoil drain plug?
Cheers,
Mark
Yellow Koni's
Re: Alternator time
Post by Shoppinit » Thu Jan 26, 2017 11:20 am
I don't prefill oil filter but I prime the engine on the starter motor. Fuse 32 29 will stop the engine starting.
I always replace the gasket and plug. At least replace the gasket.
mavada
Re: Alternator time
Post by mavada » Thu Jan 26, 2017 1:29 pm
Motul 8100 x clean 5w40 is going in.
Yellow Koni's
Re: Alternator time
Post by Shoppinit » Thu Jan 26, 2017 1:58 pm
Is it 505.01?
mavada
Re: Alternator time
Post by mavada » Thu Jan 26, 2017 2:31 pm
Yes it is. Delivered tomorrow, on the road again soon...
Yellow Koni's
Users browsing this forum: asgor, Google Adsense [Bot] and 60 guests
