Alternator time
Mɐʇʇ
Re: Alternator time
Post by Mɐʇʇ » Mon Jan 16, 2017 6:45 pm
That's it.
mavada
Re: Alternator time
Post by mavada » Tue Jan 17, 2017 12:31 pm
It looks like its not an old one...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Mɐʇʇ
Re: Alternator time
Post by Mɐʇʇ » Tue Jan 17, 2017 1:30 pm
Probably a Lucas one from Euro Car Parts using a non-bosch regulator then.
Suggest checking it out and if the stator is still in good nick, replacing the regulator with the bosch one from my link above.
As long as it's mechanically OK and not worn, the regulator pack is the most likely thing - alternators are pretty simple things really.
mavada
Re: Alternator time
Post by mavada » Tue Jan 17, 2017 2:15 pm
Am i right i have to remove those 2 oil lines?
How much oil is coming out when i remove those?
Yellow Koni's
Ajc
Re: Alternator time
Post by Ajc » Tue Jan 17, 2017 10:17 pm
mavada wrote:Am i right i have to remove those 2 oil lines?
If I remember correctly . The lines on the off side are engine oil and the ones on the near side aerial gear box . You'll just get an oil coolers worth plus what ever is in the lines
Cheers Al
adowds
Re: Alternator time
Post by adowds » Tue Jan 17, 2017 11:00 pm
I did my alternator before xmas and it was a crappy job. Problem I had with the oil pipes was getting access - you need a 27mm crowfoot socket. Then, the pipe fitting started to unscrew from the filter housing, so the pipe collapsed and twisted. I ended up cutting it off with a cutting disc and replacing it all.
Both those pipes are engine oil - I took the filter off and drained the sump beforehand because it needed changing anyway, so there was just the dregs in the pipe and from the cooler. One pipe out to the cooler, one return.
I had my alternator renovated by a place in Streatham, SW16, Grove Auto Parts. 28 Rowan Road, they did a top job, new bearings, new rectifier, painted, all good. £120 - pretty decent.
mavada
Re: Alternator time
Post by mavada » Wed Jan 18, 2017 11:15 am
Think its normal oil coming out of the ic hose?
Yellow Koni's
adowds
Re: Alternator time
Post by adowds » Wed Jan 18, 2017 11:19 am
Yep, I had a little more actually. Good luck!
mavada
Re: Alternator time
Post by mavada » Wed Jan 18, 2017 11:50 am
Did you manage to loose tension on the belt from underneath?
And put some weight on the belt to prevent it rolling from other rollers?
Yellow Koni's
adowds
Re: Alternator time
Post by adowds » Wed Jan 18, 2017 11:59 am
Yep - if I remember right, you just put a 1/2 inch drive bar into a hole on the tensioner and you can lever it round. It's quite hard, so I used a big bar. You can't really see much but it's easy enough once you work it out.
mavada
Re: Alternator time
Post by mavada » Wed Jan 18, 2017 12:12 pm
Ive got a pic from Shoppinit cambelt guide (thanks Ben), lets see if i can find it in the narrow area from underneath...
Yellow Koni's
adowds
Re: Alternator time
Post by adowds » Wed Jan 18, 2017 12:17 pm
Yep - I panicked and faffed about a bit, but it was easy enough in the end. Much worse awaited me haha!
mavada
Re: Alternator time
Post by mavada » Wed Jan 18, 2017 12:20 pm
Does it matter turning it clock or anti clockwise?
Yellow Koni's
Re: Alternator time
Post by Shoppinit » Wed Jan 18, 2017 12:23 pm
Yes.
mavada
Re: Alternator time
Post by mavada » Wed Jan 18, 2017 12:36 pm
Clockwise it is?
Yellow Koni's
Users browsing this forum: asgor, Bing [Bot], Google [Bot], Google Adsense [Bot] and 62 guests
