Alternator time
mavada
Alternator time
Post by mavada » Sat Jan 14, 2017 10:38 am
Hi all,
Now using the 6 as a daily driver, the battery light and voltage drop (as shown in the pic) issue is seen while driving.
I thought it was because of a bad battery and replaced that some years ago, but now the car isnt connected to the battery charger/conditioner at night, it looks like the Alternator is the culprit.
Will have a look to take it out and see if i can just replace some bits and pecies or order a New one....
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
bilko1
Re: Alternator time
Post by bilko1 » Sat Jan 14, 2017 10:45 am
You can buy a voltage regulator which includes the brushes. Don't forget to check the connections on the bulkhead under the expansion tank.
mavada
Re: Alternator time
Post by mavada » Sat Jan 14, 2017 10:57 am
Do you have a pic from that connection?
Yellow Koni's
Re: Alternator time
Post by Shoppinit » Sat Jan 14, 2017 11:11 am
Rule 42: confirmed.
This is the fuse:
viewtopic.php?f=2&t=108097&p=652713&hilit=200A#p652713
But it's unlikely to be that in your case because your car has been garaged for years, hasn't it?
Most likely the regulator.
Re: Alternator time
Post by Shoppinit » Sat Jan 14, 2017 11:20 am
Part number: 077 903 803A
Equivalents:
Beru 0190005093 or GER 093 http://www.topersatzteile.de/motoroel/beru/7020835
BOSCH: F 00M 144 138 or F 00M 145 247 or F 00M 145 357
/actually that link will give you a load of other equivalencies.
Re: Alternator time
Post by Shoppinit » Sat Jan 14, 2017 11:32 am
Don't think the RS6 alternator has a viscous pulley does it? I replaced an alternator on a Golf 4 recently where the viscous pulley had hari-kari'd. The rest of the alternator was fine.
Re: Alternator time
Post by chunky79 » Sat Jan 14, 2017 12:42 pm
Normal pulley on ours, you unhelpful jerk.
Re: Alternator time
Post by bam_bam » Sat Jan 14, 2017 1:08 pm
chunky79 wrote:Normal pulley on ours, you unhelpful jerk.
lol'd.
Mɐʇʇ
Re: Alternator time
Post by Mɐʇʇ » Sun Jan 15, 2017 1:08 pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1338499876
I bought this regulator - it was a genuine bosch part.
mavada
Re: Alternator time
Post by mavada » Mon Jan 16, 2017 9:19 am
Thanks guys for the info.
How do i loosen the tension on the belt? Think somewhere above the alternator, easy accessible?
Yellow Koni's
Nobby
Re: Alternator time
Post by Nobby » Mon Jan 16, 2017 9:55 am
The tensioner is spring loaded, kinda middle of the engine. Have a look at the cambelt guide. Big spanner and twist it then pop the belt off.
Daytona RS6 Avant
Re: Alternator time
Post by chunky79 » Mon Jan 16, 2017 10:09 am
Nobby wrote:The tensioner is spring loaded, kinda middle of the engine. Have a look at the cambelt guide. Big spanner and twist it then pop the belt off.
This.
It's not too bad to do, just awkward.
mavada
Re: Alternator time
Post by mavada » Mon Jan 16, 2017 12:26 pm
Which kind of hex bits do i need, in mm?
Yellow Koni's
Mɐʇʇ
Re: Alternator time
Post by Mɐʇʇ » Mon Jan 16, 2017 6:22 pm
Yeh, in RS6 terms, it's an easy job. :bash:
Ajc
Re: Alternator time
Post by Ajc » Mon Jan 16, 2017 6:41 pm
MattV8 wrote:Yeh, in RS6 terms, it's an easy job. :bash:
Easy as in you get too leave the engine in the car for once :jump:
Cheers Al
