First VCDS Auto Scan
HDPete
Post by HDPete » Thu Jan 05, 2017 7:45 pm
I'm really impressed with the speed of the Auto Scan in VCDS with the HEX V2 cable (2.5 minutes). I've done an initial scan and there are a few errors stored. Do I need to worry about any of them? Some seem to have occurred at the factory (as no date stamp is stored).
Would the next step be to clear the codes and re-scan before heading off to tweak anything?
RESULTS:
Thursday,05,January,2017,18:09:18:08872
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2 (x64) HEX-V2 CB: 0.4334.4
Data version: 20161129 DS267.0
www.Ross-Tech.com
VIN: xx License Plate:
Mileage: 6760km-4200mi Repair Order:
Chassis Type: 4G (4G8)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 28 30 34 36 3B 3C 42
44 46 52 53 55 5F 62 65 69 6C 6D 72 82 85 8B 8E 8F 90 BA
VIN: xx Mileage: 6760km-4200miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
30-Special Function II -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
82-Heads Up Display -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: OK 0000
8E-Image Processing -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
BA-Motor Mounts -- Status: OK 0000
Address 01: Engine (------CWUC) Labels: Redir Fail!
Part No SW: 4G0 906 560 F HW: 4H0 906 014
Component: 4.0l V8TFSI / H63 0001
Revision: NCH63---
Coding: 122A00326556010B3800
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM40TFS0114G0906560F 001002
ROD: EV_ECM40TFS0114G0906560F.rod
VCID: 2B000D3963871ADF9AB-807E
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 4G0 927 158 BH HW: 0BK 927 156 AM
Component: 0BK 40TFSIRdW H19 1010
Revision: --H19---
Coding: 000001
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMAL551211 002022
ROD: EV_TCMAL551211_002_AU48.rod
VCID: 75B4EB41F5431C2F3CF-8020
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4G0 907 379 T HW: 4G0 907 379 T
Component: ESP9 Premium H01 0100
Revision: -------- Serial number: --------------
Coding: 62B7DA4946ED5B92BF00
ASAM Dataset: EV_ESP9BOSCHAU57X 004018
ROD: EV_ESP9BOSCHAU57X_VW51.rod
VCID: 42DE409DF40DFB9749D-8016
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 HP HW: 4H0 907 064 HP
Component: BCM2 2.0 H61 0824
Revision: 00002001
Coding: 05B96F4E000000000000
VCID: 7EA6F46DC0F55F776D5-802A
Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
Component: J764 ELV MLB H40 0046
Serial number: 3215000196510002
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
Component: KLIMA 4 ZONEN H14 0113
Serial number: 18071600040021
Coding: 682210B81D0000
ASAM Dataset: EV_AirCondiComfoUDS 003008
ROD: EV_AirCondiComfoUDS_003.rod
VCID: 6A8EC83DACFDC3D7A1D-803E
2 Faults Found:
0276 - Engine Off Timer Performance
P150A 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 184
Mileage: 5410 km
Date: 2016.12.02
Time: 00:20:24
Voltage terminal 30: 9.95 V
Terminal 15 status: Terminal 15 on
0386 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 197
Mileage: 6025 km
Date: 2016.12.11
Time: 15:39:07
Voltage terminal 30: 11.30 V
Outside air temperature: 10.5 ∞C
Energy management deactivation stage: 1
Address 09: Cent. Elect. (J519) Labels: Redir Fail!
Part No SW: 4H0 907 063 GG HW: 4H0 907 063 AG
Component: BCM1 2.0 H20 0368
Revision: 14020001 Serial number: 00001417879301
Coding: 0105001440349FE2E90140C7A0001800CF9DE70A2F08020180000894E100170200400009090000
VCID: 73B0D559FBB7021F12B-8026
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 160611 H38 0080
Serial number: 160618082421
Coding: 0045F7
Subsystem 2 - Part No SW: 8U0 955 559 C HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 62064768
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BG HW: 4G0 941 531 BG
Component: E1 - LDS H07 0044
Serial number: 08 07 2016 00001289
Subsystem 4 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
Component: EVLS-SG H08 0300
Serial number: WA122599000017979367
Coding: 020300
Subsystem 5 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H01 0005
Serial number: AAF84B3800PAG0MUFU03
Address 10: Park/Steer Assist (J791) Labels: None
Part No SW: 4G0 919 475 H HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0080
Revision: -------- Serial number: 56231620100269
Coding: B93B26
ASAM Dataset: EV_EPHVA2CAU64X0000 001014
ROD: EV_EPHVA2CAU64X0000.rod
VCID: 36362C4DA8C55737F55-8062
Address 13: Auto Dist. Reg (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 561 B HW: 4G0 907 561
Component: ACC3 H21 0055
Serial number: 00000000000000
Coding: 7F04010102
ASAM Dataset: EV_AdaptCruisContrAU57X 002015
ROD: EV_AdaptCruisContrAU57X_002.rod
VCID: 290CF731697B08CF687-807C
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P100ANUKQ
Coding: 30333130313730323631554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 3B203D7993E78A5F0AB-806E
Crash sensor for side airbag: driver side:
Serial number: 3575HRB401055CG271ED
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB400255CGA78O/
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB40045744AR9L.
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB400A57188R1M-
Crash sensor for front airbag: driver side:
Serial number: 3554VRB401G5752IMI1D
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB40125752CSH97
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
Component: Lenks.Modul H04 0005
Revision: -------- Serial number: 90372PGI0005Y
Coding: 0000FD
VCID: 37282149AF4FAE3FEE3-8062
Subsystem 1 - Part No SW: 4G0 951 528 J HW: 4G0 951 528 J
Component: E221 - MFL H08 0010
Serial number: 22 05 2016 F0101368
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G0 920 983 HW: 4G0 920 983
Component: TBenGb AccNv H14 0218
Revision: 11001108 Serial number: 658120716596031
Coding: 338F910B9F512600010400
ASAM Dataset: EV_RBD4K 004060
ROD: EV_RBD4K.rod
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G8 907 468 H HW: 4G8 907 468
Component: J533--Gateway H15 0096
Revision: -------- Serial number: 00000002323772
Coding: C0ED07481C
ASAM Dataset: EV_GatewPkoUDS 002000
ROD: EV_GatewPkoUDS_002.rod
VCID: 3D2433618DF3846F34F-8068
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
Component: J367-BDMHella H10 9070
Serial number: 4682660704
Voltage stabilizer:
2 Faults Found:
12290 - Quiescent Current
U1406 00 [009] - Too High
Freeze Frame:
Fault Priority: 7
Fault Frequency: 233
Reset counter: 171
Mileage: 315 km
Date: 2016.08.27
Time: 17:21:38
Voltage terminal 30: 12.1 V
Voltage terminal 15: 0.0 V
Control Module temperature: 23 ∞C
System status: LIN_active
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
12291 - Energy Management Active
U140B 00 [008] - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 116
Reset counter: 211
Mileage: 315 km
Date: 2016.08.27
Time: 20:24:58
Control Module temperature: 22 ∞C
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Address 22: AWD (J492) Labels: 4H0-907-163.clb
Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
Component: 4 Wheel Drive H19 0200
Serial number: 001507160001007
ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
ROD: EV_AllWheelDiffeQSPFR.rod
VCID: 280AF235727131C7779-807C
Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
Part No SW: 4G0 919 158 R HW: 4G0 919 158 R
Component: KLIMA FOND H08 0113
Serial number: 19071600040029
Coding: 22
ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
ROD: EV_ClimaContrUnitRearUDS_003.rod
VCID: 3E26346D80F59F772D5-806A
1 Fault Found:
0075 - Button or Switch in Operating Unit
B10C7 07 [008] - Mechanical Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 213
Mileage: 6497 km
Date: 2016.12.16
Time: 16:39:55
Outside air temperature: 12.0 ∞C
Left rear vent temperature: 15.2 ∞C
Address 30: Special Function II (J843) Labels: 8K0-907-440.clb
Part No SW: 4H0 907 440 HW: 4H0 907 440
Component: STS H06 0030
Revision: S0H06000 Serial number: 00000000096336
Coding: 01010101000000000001000102
VCID: 6492A6054E5995A79B1-8030
Address 34: Level Control (J197) Labels: 4G0-907-553.clb
Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
Component: LUFE-DAEMPFER H19 0783
Coding: 008003
ASAM Dataset: EV_AirSuspe 003025
ROD: EV_AirSuspe_VW51.rod
VCID: 2F381929579F66FFB63-807A
1 Fault Found:
403200 - Function Shut-Off Active
C10C8 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 184
Date: 2000.00.00
Time: 00:00:00
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000208845300
Coding: 00781B0000006001000001010101102030303232203232
VCID: 77A8E149EFCF6E3F2E3-8022
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
Component: SARA 6D red H04 0056
Revision: -------- Serial number: EJ1BPA7E02A7D4
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2_VW51.rod
VCID: 37282149AFCFAE3FEE3-8062
Address 3C: Lane Change (J769) Labels: 5Q0-907-566.clb
Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
Component: SWA Master H08 0070
Serial number: 0409951366
Coding: 040322
ASAM Dataset: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_AU21.rod
VCID: 392C277199DBB84F187-806C
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
Component: SWA Slave H08 0070
Serial number: 0410085045
Coding: 040322
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
Component: TSG FA H04 0511
Coding: 011F16015E21628002080013
VCID: 45D45B81E5A3CCAF6CF-8010
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
Component: RCevo H54 0202
Revision: 00000001 Serial number: 0000092813
Coding: 101101010001
ASAM Dataset: EV_RCEPS 106007
ROD: EV_RCEPS_106.rod
VCID: 3A2E387D9CDDB35711D-806E
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0411447104
Coding: 013B0E22A0B93895C33009842E0313470000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177 A
Component: Sensor, DWA 005 0002
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J245 PS20.403 H03 0004
Serial number: 0000FST0012TX7000000
Coding: 901F00
Subsystem 4 - Part No SW: 4G0 947 135 K HW: 4G0 947 135
Component: Dachelektroni H10 0100
Serial number: 0000000AP00023313389
Coding: 010000
Subsystem 5 - Part No SW: 4G9 959 591 A HW: 8V3 959 591 A
Component: J394 PS20.403 H03 0004
Serial number: 0000FST0012W8MT00000
Coding: 801F00
Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93844458
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 J HW: 4G8 959 792 G
Component: TSG BF H03 0511
Coding: 011F16015E21628002080002
VCID: 46D65C8DD8A5C7B7655-8012
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 L HW: 4H0 907 801 A
Component: EPB-4 H05 0017
Revision: -------- Serial number: 00000001919434
ASAM Dataset: EV_ParkiBrake 001029
ROD: EV_ParkiBrake_AU57.rod
VCID: 313C1F5141AB700FA07-8064
Address 55: Headlight Range (J745) Labels: 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
Component: MxB-ECU 001 0100
Coding: 04FE02202A170200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
VCID: 34321645BEB94527CB1-8060
Led Headlamp Powermodule Left:
Subsystem 1 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H07 7560
Coding: E01F00
Led Headlamp Powermodule Right:
Subsystem 2 - Part No SW: 7PP 941 472 J HW: 7PP 941 472 J Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H07 7560
Coding: E01F00
Matrix Headlamp Powermodule 1 Left:
Subsystem 3 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo li. H03 0031
Coding: E01F00
Matrix Headlamp Powermodule 1 Right:
Subsystem 4 - Part No SW: 4H0 941 329 A HW: 4H0 941 329 A Labels: 3D0-941-329.CLB
Component: MxB LeiMo re. H03 0031
Coding: E01F00
1 Fault Found:
5353456 - Fog mode active
C118E 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 175
Mileage: 5138 km
Date: 2016.11.25
Time: 16:59:27
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 4G1 035 021 F HW: 4G1 035 021 D
Component: MU-H-LND-EU 052 0670
Serial number: A733G0G7503833
Coding: 017562010000000013111102000A00332F0008E7F1700100DF
ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
VCID: 1D64D3E12D33E46F14F-8048
Data medium:
Subsystem 1 - Part No SW: V03 959 801 FB HW: -----------
Component: ECE 2016/2017 --- 0153
Serial number: --------------------
Display unit 1 for multimedia system:
Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
Component: DU8 C7 SV H63 0007
Serial number: AUZ8Z9GY805L75
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349PGM0000G
Compact Disc Database:
Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 1013
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 J HW: 4G8 959 795 G
Component: TSG HL H03 0511
Coding: 010F14004021628002080002
VCID: 49CC57B1C9BB28CF887-801C
Address 65: Tire Pressure (-----) Labels: 3Y0-907-273.clb
Part No SW: 4H0 907 273 B HW: 4H0 907 273 B
Component: RDKBERU25 H10 0820
Serial number: 10000000030209
ASAM Dataset: EV_RDKBERU25 003014
ROD: EV_RDKBERU25_AU57.rod
VCID: 2A0E083D6C7D03D761D-807E
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 4G8 907 383 B HW: 4G8 907 383 B
Component: Anhaenger H20 0160
Revision: 7B001003 Serial number: 0411281722
Coding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001005
ROD: EV_TrailFunctGener2Hella_VW26.rod
VCID: 33301559BBB7421FD2B-8066
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
Component: TopView H09 0361
Revision: 11001001 Serial number: 82330JG0187589
Coding: 0218000001000000010102000000
ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
ROD: EV_CamerSysteTopViewAUDI_008.rod
Address 6D: Trunk Elect. (----) Labels: Redir Fail!
Part No SW: 4G9 959 107 C HW: 4G9 959 107 B
Component: HDSG-Modul H05 0151
Revision: 14005001 Serial number: 188601458
Coding: 093205C031
ASAM Dataset: EV_HDSGAu572 001022
ROD: EV_HDSGAu571.rod
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H03 0511
Address 82: Heads Up Display (J898) Labels: 4G0-919-604.clb
Part No SW: 4G0 919 604 N HW: 4G0 919 604 N
Component: HeadUpDisplay H08 0306
Revision: 00000000 Serial number: 00000000000000
Coding: C68000
ASAM Dataset: EV_HUDContiC7 001027
ROD: EV_HUDContiC7.rod
Address 85: On Board Cam. (J852) Labels: None
Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
Component: DPC-SG H27 0081
Revision: -------- Serial number: 262130025421000
Coding: EA160000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 2C020E2566891DE7931-8078
Address 8B: Adaptive Cruise 2 (J428) Labels: 4H0-907-561.clb
Part No SW: 4G0 907 541 B HW: 4G0 907 541
Coding: 7F04010102
ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
ROD: EV_AdaptCruisContr2AU57X_002.rod
VCID: 2708F1097F6F3EBF7E3-8072
Address 8E: Image Processing (J851) Labels: 4H0-907-107-V2.clb
Part No SW: 4H0 907 107 H HW: 4H0 907 107
Component: BV-SG H34 0090
Serial number: 005002451907167
Coding: 04C23A1E1111
ASAM Dataset: EV_BC7 001001
ROD: EV_BC7.rod
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
Component: RGS-VL H16 0080
Coding: 0066E608031F0376070308004240C2010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
Component: RGS-VR H16 0080
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 323E105D44AD4B17D9D-8066
Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
Part No SW: 4H0 907 145 B HW: 4H0 907 145
Component: AEM - LEAR H10 0008
Revision: 00001001 Serial number: 97813007111801
ASAM Dataset: EV_AEMLearAU64X 002016
ROD: EV_AEMLearAU64X.rod
End----------(Elapsed Time: 02:37, VBatt start/end: 11.6V/11.6V)-----------
Mav8
Re: First VCDS Auto Scan
Post by Mav8 » Thu Jan 05, 2017 8:47 pm
Yup
Clear the codes and see what comes back.
RS3- Sepang
Gone
F80-M3
B7-RS4
B5-RS4
HDPete
Post by HDPete » Fri Jan 13, 2017 3:37 pm
Any idea how to enable the rip from CD on the facelift? It seems that the hidden menu isn't accessible so can't do it that way.
Post by MikeFish » Fri Jan 13, 2017 10:03 pm
I haven't seen a way to access the hidden menu on facelift yet.
But just rip to an SD card or usb drive when you get home.
HDPete
Post by HDPete » Fri Jan 13, 2017 10:26 pm
It's getting more tricky since I upgraded to new Macs with no internal CD/DVD-Rom. Need to get an external unit (or find that blasted hidden menu!)
RSllama
Post by RSllama » Sun Jan 15, 2017 9:14 pm
The lovely fog mode.....got this on my 2016 model. It messes with the camera system and radar (if you got the safety assist). Went to Reading to get it fixed and they reset it after the bulletin told them how to take it out of fog mode. Trouble is the car then goes back into fog mode and then back to dealer to fix. The symptoms are; high beam assist not working with on-coming vehicles, speed limit display incorrect values and crash mitigation goes into melt-down.
Audi is fully aware of this and should have fixed this as I brought it to their attention over a year ago. As for my car, had to reject it as it had 24 faults and it tried to kill me and my family when the crash mitigation put the car into emergency stop on the outside lane of the duel carriageway for no reason. The good thing is there is no way to over-ride the crash mitigation so the car behind was a little close to rear ending me. After the third time it did it I had had enough. The dealer said they could not find a fault....trouble is the system does not provide a fault code or give indication of system activated, so there is no fault right! The dealer did admit that both front and rear sensors can only be found to work or not once you have had the accident. Interestingly, new models in the Audi range now have an over-ride in the MMI (Q7,new Q5 etc) but not RS6 or RS6 performance.
Don't worry too much about the codes, just drive and enjoy the car. Hope yours is a good one.
PS Ive had 57 Audis most of them RS and S but the most fun was the RS2 and SWB quattro S1.
Post by MikeFish » Sun Jan 15, 2017 9:20 pm
RSllama wrote:The lovely fog mode.....got this on my 2016 model. It messes with the camera system and radar (if you got the safety assist). Went to Reading to get it fixed and they reset it after the bulletin told them how to take it out of fog mode. Trouble is the car then goes back into fog mode and then back to dealer to fix. The symptoms are; high beam assist not working with on-coming vehicles, speed limit display incorrect values and crash mitigation goes into melt-down.
I have an option to turn of brake assist in my MMI.
RSllama
Post by RSllama » Sun Jan 15, 2017 10:38 pm
Turning off the brake assist does not turn off the collision mitigation. It is a different system.
Post by MikeFish » Mon Jan 16, 2017 12:27 am
RSllama wrote:Turning off the brake assist does not turn off the collision mitigation. It is a different system.
What's the difference between the 2 systems? I don't think I've ever heard of collision mitigation other than brake assist.
RSllama
Post by RSllama » Mon Jan 16, 2017 1:42 am
On RS6s if you have the safety assist pack you have the radar on the front bumper (black circles in both side vents) and this detects moving objects in front of the car. The radar is used for the brake assist and cruise control etc. If you have the car running and walk in front of the car the radar and camera picks up that there is a moving object (much like the parking sensors). Leaves blowing across the front of the car will do it too. Oddly this system is rather flawed and mini-roundabouts, kerbs, rain and mud will set it off too. This system is fitted to all VW Group cars and many owners have been caught out by it. The last main press piece was in The Sunday Times money section last August where a VW driver was having problems with it on their Passat.
If the system worked properly it would be a life saver but it does not hence the new model/updated model cars have over-rides in the MMI. Why would they have this if it worked properly? Ask yourself when you are lucky enough to go to the Audi track experiences, do the RS6s have the safety assist pack on them?
I brought this to the attention of Audi last year and asked them what would happen if you were on a track day/track race and the system went off? They never answered the question, they just said they would pass on all comments to the relevant departments. I talked to Pistonheads and What Car? about it and both never ran the story (even though it is in the public domain already). Autocar is thinking about it. I took it up with DVLA and VSBC at VOSA but they said it was very difficult to force car manufactures to recall their cars on safety systems. It is just frightening how no one really wants to look into this. Perhaps the recent story with Skoda and the chap who was killed on the M40 when his cruise control system was (allegedly) faulty put the mockers on it.
I love these cars but am not happy with the amount of systems that they now have on them, hence why I like my B5 RS4 so much.
Post by MikeFish » Mon Jan 16, 2017 1:49 am
That's what I was referring to as brake assist. I just looked up the proper name, it is brake gaurd that I was talking about and that is what I thought I could turn off from the MMI. But I might be getting confused now. I'll check which system I can change in the MMI tomorrow.
Post by MikeFish » Mon Jan 16, 2017 8:54 am
RSllama
Post by RSllama » Mon Jan 16, 2017 1:33 pm
MikeFish wrote:Image
Do you have the radar on the front bumper side vents? If so, you can't turn it off as it over-rides the brake guard settings in the MMI.
Post by MikeFish » Mon Jan 16, 2017 1:37 pm
Yes I have the assistance pack, I don't think you can specify brake guard without the assistance pack as it uses the radars. Isn't the collision mitigation you are talking about the same as brake guard?
Post by MikeFish » Mon Jan 16, 2017 1:42 pm
Describes braking guard (for an A5 but it is similar):
https://www.audi-mediacenter.com/en/the ... stems-3036
Users browsing this forum: No registered users and 65 guests
