Alternator time
Alternator time
Hi all,
Now using the 6 as a daily driver, the battery light and voltage drop (as shown in the pic) issue is seen while driving.
I thought it was because of a bad battery and replaced that some years ago, but now the car isnt connected to the battery charger/conditioner at night, it looks like the Alternator is the culprit.
Will have a look to take it out and see if i can just replace some bits and pecies or order a New one....
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
Re: Alternator time
You can buy a voltage regulator which includes the brushes. Don't forget to check the connections on the bulkhead under the expansion tank.
Re: Alternator time
Do you have a pic from that connection?
Yellow Koni's
Yellow Koni's
Re: Alternator time
Rule 42: confirmed.
This is the fuse:
viewtopic.php?f=2&t=108097&p=652713&hilit=200A#p652713
But it's unlikely to be that in your case because your car has been garaged for years, hasn't it?
Most likely the regulator.
This is the fuse:
Re: Alternator time
Part number: 077 903 803A
Equivalents:
Beru 0190005093 or GER 093 http://www.topersatzteile.de/motoroel/beru/7020835
BOSCH: F 00M 144 138 or F 00M 145 247 or F 00M 145 357
/actually that link will give you a load of other equivalencies.
Equivalents:
Re: Alternator time
Don't think the RS6 alternator has a viscous pulley does it? I replaced an alternator on a Golf 4 recently where the viscous pulley had hari-kari'd. The rest of the alternator was fine.
Re: Alternator time
Normal pulley on ours, you unhelpful jerk.
Re: Alternator time
lol'd.chunky79 wrote:Normal pulley on ours, you unhelpful jerk.
Re: Alternator time
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 1338499876
I bought this regulator - it was a genuine bosch part.
Re: Alternator time
Thanks guys for the info.
How do i loosen the tension on the belt? Think somewhere above the alternator, easy accessible?
Yellow Koni's
Yellow Koni's
Re: Alternator time
The tensioner is spring loaded, kinda middle of the engine. Have a look at the cambelt guide. Big spanner and twist it then pop the belt off.
Daytona RS6 Avant
Re: Alternator time
Nobby wrote:The tensioner is spring loaded, kinda middle of the engine. Have a look at the cambelt guide. Big spanner and twist it then pop the belt off.
This.
It's not too bad to do, just awkward.
Re: Alternator time
Which kind of hex bits do i need, in mm?
Yellow Koni's
Yellow Koni's
Re: Alternator time
Yeh, in RS6 terms, it's an easy job.
chunky79 wrote:It's not too bad to do, just awkward.Nobby wrote:The tensioner is spring loaded, kinda middle of the engine. Have a look at the cambelt guide. Big spanner and twist it then pop the belt off.
Re: Alternator time
Easy as in you get too leave the engine in the car for onceMattV8 wrote:Yeh, in RS6 terms, it's an easy job.![]()
Cheers Al
