Connecting mp3 player to blows rns-e stereo?
jonson66
Post by jonson66 » Wed Nov 23, 2016 10:18 pm
Sorry if someone's already covered this, just wondering if there is a way I can connect an mp3 player to the standard stereo? I've got a cd changer in the glove box but the kids like listening to my songs off of deezer. Any help much appreciated.
Jon
PaulT
Re: Connecting mp3 player to blows rns-e stereo?
Post by PaulT » Thu Nov 24, 2016 12:11 am
There are aux input pins on connector on rear of RNSE. Check the thread below - It shows the lead that needs to be made up to 3.5mm audio jack that can be routed through into glovebox. Also recoding needed (via VCDS) to activate the Aux input n the source list on the RNSE.
Ross made up a batch of leads last year that several of us used.
viewtopic.php?f=64&t=113648
Daytona RS4
jonson66
Post by jonson66 » Thu Nov 24, 2016 12:29 am
Thanks for reply Paul. So does that need recoding with Vagcom? Also does he still have leads left as this was last year?
Jon
jonytek
Post by jonytek » Thu Nov 24, 2016 10:37 am
I installed a cable not to long ago and was straight forward, I did however need to recode. These are the bits Cable and keys to get unit out.
If you ask around the forum you might find a local member that can help you with the Vagcom.. Good luck.
BUILD THREAD
IG: @bad_rs_4
PaulT
Post by PaulT » Thu Nov 24, 2016 11:21 am
Yep that cable @jonytek links to looks right.
Yes you do need to recode using Vagcom - the change is small and details and link to Rosstech wiki are halfway down the first page of the thread i linked to.
The recoding enables the aux input and makes the AUX appear in the source list under the CD so you can select it. (In same place as you select MP3 to play from the memory cards)
I am in Camberley, Surrey and have Vagcom/VCDS, where are you?
Daytona RS4
jonytek
Post by jonytek » Thu Nov 24, 2016 12:03 pm
It did take a while for the change to kick in once I recoded mine. Not sure what it was, recoded, didn't work, went for a drive and tried again and it worked - just something to keep in mind.
BUILD THREAD
IG: @bad_rs_4
jonson66
Post by jonson66 » Thu Nov 24, 2016 5:12 pm
Thanks for the help chaps. Will purchase a cable and keys as I don't have a set. That would be helpful Paul but unfortunately I'm from the Bristol area but thanks for the generous offer
jonson66
Post by jonson66 » Thu Nov 24, 2016 9:23 pm
Cable and keys purchased. And possibly Vagcom if the price is right. Unless anyone is selling Vagcom on here?
jonson66
Post by jonson66 » Wed Dec 07, 2016 9:58 am
Hi all. I have the cable and keys. Also I now have a snap on solus pro. Hopefully I can code using this. My only question is I read that the firmware must be after 2008? Is there a way I can check?
jonson66
Post by jonson66 » Fri Dec 09, 2016 12:34 pm
Anybody? Everybody?
mikep99
Post by mikep99 » Fri Dec 09, 2016 12:44 pm
you can check on the RNS-E, think its under the setup menu somewhere. The menu should look like this:
Its the software version that you need to know..
jonson66
Post by jonson66 » Fri Dec 09, 2016 12:46 pm
Ahh nice one Mike thank you! What firmware does it need to be?
mikep99
Post by mikep99 » Fri Dec 09, 2016 12:49 pm
can't remember tbh but I think the latest RNSE mk1 official firmware is 650
EDIT - 650 is required for Aux in
jonson66
Post by jonson66 » Fri Dec 09, 2016 12:50 pm
Ok mate thanks for your help with this
jonson66
Post by jonson66 » Fri Dec 09, 2016 1:39 pm
Well mine is 0430 so it's out of date. Anyone fancy lending me a genuine cd for beer money? I'll pay postage etc
Users browsing this forum: Majestic-12 [Bot], MK1_LOVE and 187 guests
