Hi All,
Just wondered how accurate everyone's outside temp gauge is. Mine today is showing an optimistic 18 degrees C. Is this normal for the car due to heat-soak from the engine or do I have a faulty sensor?
Is there a way to get to the sensor if it is faulty without taking the entire front bumper off?
John
Outside Air Temp-High Reading?
B7 RS4 Avant Sprint Blue.
MK7 Golf GTD about to arrive for the daily!
Re: Outside Air Temp-High Reading?
Maybe it's just unusually warm for October?
Mine doesn't go up with engine temp or car speed or anything like that, it's pretty good. But it was fairly mild today I think.
My one started reading high after I had a forge oil cooler fitted. At first I thought the sensor had taken a knock during the install but it still reads high after a new one had been fitted.
The sensor is relocated with the forge kit fitted so guess that must be the cause with mine.
Misano Red RS4 B7 Avant
I have the forge oil cooler and no issues with temp sensor.
Hmm I was going to ask the very same question mine read once 32 degrees and was definitely more like 20
Mine read high most days to be honest I'm convinced mine is faulty
so it's located up front ?
Easy change anyone ?
Interesting, I must have a wiring fault then.MikeFish wrote:I have the forge oil cooler and no issues with temp sensor.
As I live in Scotland I will probably just leave it and assume it is always cold outside...
