TPMS
TPMS
I keep having the TPMS (Tyre Pressure Monitoring System) message appear on my display. I have reset countless times, but it keeps coming back. Does anyone know why this is happening (aside from the obvious of tyre pressures being down - which they're not) and how to fix?
Thanks.
Thanks.
Re: TPMS
Quick fix: disable with vagcom.MarksRS wrote:I keep having the TPMS (Tyre Pressure Monitoring System) message appear on my display. I have reset countless times, but it keeps coming back. Does anyone know why this is happening (aside from the obvious of tyre pressures being down - which they're not) and how to fix?
Thanks.
Long fix. Replace all sensors.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Re: TPMS
Don't know if I got lucky but I just unplugged the TPMS antenna behind the rear bumper grille and plugged it back in and its worked perfect ever since. Its worth having the sensors checked at a local tyre fitters, I used National tyres and they checked them for free, it helped narrow the fault down to the antenna.
Audi RS6 c7 2014| Estoril Blue | Dynamic pack | Sports Exhaust.
Re: TPMS
Thanks. Audi reset it via the trip computer (which is what I was doing anyway), but I'll try and unplug the antenna, however not being the most hands-on, can you advise exactly where this is? A picture would speak a thousand words!
Thanks.
Thanks.
Re: TPMS
I then switched the ignition on until it recognized there was a fault with TPMS system and then turned the ignition off, replaced the antenna, started the car and its been fine ever since..... worth a try, you never know your luck!
Re: TPMS
I've got the exact same issue occurring now. Please post if you attempt the repair…MarksRS wrote:I keep having the TPMS (Tyre Pressure Monitoring System) message appear on my display. I have reset countless times, but it keeps coming back. Does anyone know why this is happening (aside from the obvious of tyre pressures being down - which they're not) and how to fix?
Thanks.
Current: 07 RS4 Daytona Grey, 987 Boxster S GT Silver, MkV GTI, Honda VFR
Re: TPMS
@markrs Did this solution work for you?
Re: TPMS
How old are your TPMS sensors as the batteries run out after a number of years. So you will need to replace them or as said disable the antenna.
Users browsing this forum: Bing [Bot] and 79 guests
