Help with fault codes
I have a couple of fault codes relating to an intermittent fault on both cooling fans - they cut in whenever they like. Sounds like a jet turbine warming up.
18080 - Coolant fan control 1
P1672-004- Open or short to ground, intermittent
18308 - Coolant fan control 2
P1900 - 004 - Open or short ground, intermittent
Any help appreciated. The indie reckons it could be a 10 mins or 10 hour job, so any pointers where to start looking first would be a great help.
Re: Help with fault codes
Quick search brought up this thread, which may help
viewtopic.php?t=107031
Sent from mobile with fat fingers
Thanks TechNick. I should have thought to do a search first.TechNick wrote:Quick search brought up this thread, which may help
Is there one control unit for both fans ? If not, then is it likely both ECM have died as both fans are coming up with the same fault in my case ?
- 1st Gear
Is the water temp reading fine? I had a faulty sensor that played havoc with my fans. Can't remember the fault code it threw, though. I made a thread for it a little while back.
Sent fra min SM-N910F via Tapatalk
2003 RS6 Avant, Daytona grey
2012 Toyota GT86
2014 Toyota Prius Plus 7
2012 Toyota GT86
If you clear them, do they come back? Could be old codes from a previous wire disconnection.
Do an output test to spin up the fans and see if they do.
If not, check the fuses behind the dash. They are big ones. I'd be surprised if you had an intermittent code if the fuses were gone, but it's something that needs to be eliminated.
Then log your temps (to the ECU and to the dash) to see if they are coherent.
Each fan has its own controller. One of them is integrated into the fan unit, the other is bolted under the chassis member. Someone posted a photo of the location recently.
Water temp is fine.
I'll pass the other comments onto the garage, cheers guys.
How do you know?Bradders911 wrote:Water temp is fine.
Fair point - I was going by the dash gauge.
The dash uses a different coolant temp feed to the ECU (plus it's pinned to 90 unless there is a huge variation).
Which is a good point. So best practice - even the slightest deviation above 90, no matter how minor - stop IMMEDIATELY.
Shoppinit wrote:The dash uses a different coolant temp feed to the ECU (plus it's pinned to 90 unless there is a huge variation).
MattV8 wrote:Which is a good point. So best practice - even the slightest deviation above 90, no matter how minor - stop IMMEDIATELY/or pull over in a safe place!
What was the outcome?
Dunno I rejected the car......
