Help with fault codes
Bradders911
Post by Bradders911 » Thu Oct 20, 2016 9:42 am
I have a couple of fault codes relating to an intermittent fault on both cooling fans - they cut in whenever they like. Sounds like a jet turbine warming up.
18080 - Coolant fan control 1
P1672-004- Open or short to ground, intermittent
18308 - Coolant fan control 2
P1900 - 004 - Open or short ground, intermittent
Any help appreciated. The indie reckons it could be a 10 mins or 10 hour job, so any pointers where to start looking first would be a great help.
TechNick
Re: Help with fault codes
Post by TechNick » Thu Oct 20, 2016 9:46 am
Quick search brought up this thread, which may help
viewtopic.php?t=107031
Sent from mobile with fat fingers
Bradders911
Post by Bradders911 » Thu Oct 20, 2016 9:53 am
TechNick wrote:Quick search brought up this thread, which may help
Thanks TechNick. I should have thought to do a search first.
Is there one control unit for both fans ? If not, then is it likely both ECM have died as both fans are coming up with the same fault in my case ?
atledreier
Post by atledreier » Thu Oct 20, 2016 11:12 am
Is the water temp reading fine? I had a faulty sensor that played havoc with my fans. Can't remember the fault code it threw, though. I made a thread for it a little while back.
Sent fra min SM-N910F via Tapatalk
2003 RS6 Avant, Daytona grey
2012 Toyota GT86
2014 Toyota Prius Plus 7
Post by Shoppinit » Thu Oct 20, 2016 11:41 am
If you clear them, do they come back? Could be old codes from a previous wire disconnection.
Do an output test to spin up the fans and see if they do.
If not, check the fuses behind the dash. They are big ones. I'd be surprised if you had an intermittent code if the fuses were gone, but it's something that needs to be eliminated.
Then log your temps (to the ECU and to the dash) to see if they are coherent.
Each fan has its own controller. One of them is integrated into the fan unit, the other is bolted under the chassis member. Someone posted a photo of the location recently.
Bradders911
Post by Bradders911 » Thu Oct 20, 2016 1:38 pm
Water temp is fine.
I'll pass the other comments onto the garage, cheers guys.
Post by Shoppinit » Thu Oct 20, 2016 1:44 pm
Bradders911 wrote:Water temp is fine.
How do you know?
Bradders911
Post by Bradders911 » Thu Oct 20, 2016 1:48 pm
Fair point - I was going by the dash gauge.
Post by Shoppinit » Thu Oct 20, 2016 1:54 pm
The dash uses a different coolant temp feed to the ECU (plus it's pinned to 90 unless there is a huge variation).
Mɐʇʇ
Post by Mɐʇʇ » Thu Oct 20, 2016 9:29 pm
Which is a good point. So best practice - even the slightest deviation above 90, no matter how minor - stop IMMEDIATELY.
Shoppinit wrote:The dash uses a different coolant temp feed to the ECU (plus it's pinned to 90 unless there is a huge variation).
Post by chunky79 » Wed Oct 26, 2016 6:32 am
MattV8 wrote:Which is a good point. So best practice - even the slightest deviation above 90, no matter how minor - stop IMMEDIATELY/or pull over in a safe place!
Post by Shoppinit » Sun Nov 06, 2016 2:56 pm
What was the outcome?
Bradders911
Post by Bradders911 » Sun Nov 06, 2016 10:01 pm
Dunno I rejected the car......
Users browsing this forum: srichards and 76 guests
