Headlight film
Re: Headlight film
2007 black RS4 saloon. Bilstein Coilovers, MRC Re-map, Miltek non resonated valved exhaust with de-cats, Gruppe-M carbon induction, JHM manifold spacers, Stage 2 manifold, cold air feed.
Re: Headlight film
Re: Headlight film
Sounds like you bought a sheet rather than pre cut? If so, why did you buy from the US?
And you paid £90 just for customs fees? How much did you order!?!
I ordered a set of front and rear pre cut tints and they were $60 each. I also paid $67 shipping as I was in a hurry. So a total of £187 which came to about £147.
Then customs was only about 20 or 30 quid I think. I'll see if I can find it on my bank statement.
Re: Headlight film
i purchased 10 ft, and i still have no idea why the customs charge was as much as it was, as the product was only around £180 from what i remember.
Re: Headlight film
What mike said for install but use a hairdryer less heat and a week cheap washing liquid, dryer is to heat the film for the curves and keep spraying when applying the film pushing the bubbles out and protect the film.
Re: Headlight film
The supplied instructions said you can use a needle to make holes to release water / air if you can't get them out as it is self healing anyway.
Re: Headlight film
Ah, so it's the same as the ventudreshield I fitted to my R1..
Re: Headlight film
Pretty much, it's a tinted ppf. Not sure how good at healing it is, but I did make a few holes in it and can't see them anymore.
Re: Headlight film
Re: Headlight film
Tried this in 2014 and still going fine with them on headlights, fogs and rears - got a small strip (not cut to fit) for the rear spoiler light.
Got them from Ecs and MIke and Doc have the steps posted to install.
Set of: https://www.ecstuning.com/ES1867047/
Fogs: https://www.ecstuning.com/ES1867140/
Bought set above and the fogs without realising fogs were in the set as well.
So if anyone wants the fogs, get back and pm address and will send - only small so wont cost much I'd expect to post.
Front before
Front with laminx 6% and with Joey mod in lens
Closer
Cannot find a pic with the laminx but before the joey mod, if find will post up.
Rear before
Rear after
Vic
Front before
Closer
Rear before
Rear after
Vic
Re: Headlight film
Very mice
Users browsing this forum: Google [Bot] and 62 guests
