F/S B7 Space Saver Wheel
Had this as a spare for B7 RS4 instead of the puncture repair kit. Note fits on rear only
£80 posted
£80 posted
Re: B7 Space Saver Wheel
Need this gone
£50 posted or it gets binned at the weekend
is the centre the correct 57.1mm or 66.6mm?
Bore looks to be about 68mm.
Part number is 8K0 601 027D if this helps.
Re: F/S B7 Space Saver Wheel
as long as the centre bore is same or bigger and pcd/offset is correct it wont matter for a spare-its only to limp you to a tyre Shop after all...
Correct Arthur and it does fit on the rear of a B7 - trust me
Hi Ian, would the posted price include Northern Ireland?
Yes that won't a problem - as long as it's less than £50 which I'm sure it will be
Sounds good, you have PM.
Users browsing this forum: Google Adsense [Bot], steve2003rs6 and 44 guests
