Power run
jasonhudds
Power run
Post by jasonhudds » Tue Sep 13, 2016 12:31 pm
Hello all ,today I booked my recently purchased B7 RS4 in for a power run
The car is in standard form a 2007 model saloon with a full Audi service history with a respectable 63k on the clock
It made 360hp is this a reasonable result as I know they can be big variations in out put. Looking for advise, Is this a good starting point for remapping etc or would it be better to do carbon clean first any advise would be appreciated
Jason
FaisalJ
Re: Power run
Post by FaisalJ » Tue Sep 13, 2016 3:17 pm
Hard to say.
360 is a bit on the low side. That could just be bad carbon buildup, but you'd expect slightly higher if carbon was the only issue. Although, heat soak could be a factor, and the fact all dynos are different. Even the way the car is strapped down can make a difference to how it reads on the dyno!
When I recorded 365PS on a dyno last year, that got me worried that I had a vacuum leak or perhaps some sticking inlet manifold flaps. I took it into MRC, and first thing they noted was that on their dyno, it made 380PS. They commented that as the other dyno runs were done with my bonnet closed (and engine hot), I probably had heatsoak, which wouldn't have helped the figures.
I had them carbon clean the manifold while it was there, to see if it would make decent power once clean, and therefore rule out any other issues. It already had an MRC map, and made 427PS after the clean.
With regards to the age old question of "is a carbon clean worth it"? You'll get loads of different opinions, and ultimately, best to just know the facts and make a call.
- A proper carbon clean is not cheap, and the terraclean/enginecarbonclean shortcuts do not work
- You cannot prevent the carbon building up again. You can slow it by red-lining the car often
You can remap the car cleaned or dirty, doesn't really matter. Keep in mind that the main benefit of a remap is improved driveability, and not any increase in power. If you go for an MRC map, you get absolutely electric throttle response in sport mode.
Hope that helps
2007 RS4 B7 Avant
jasonhudds
Re: Power run
Post by jasonhudds » Tue Sep 13, 2016 3:42 pm
Thanks FaisalJ
Will speak to MRC
Re: Power run
Post by MikeFish » Tue Sep 13, 2016 4:45 pm
Exactly my thoughts.
360 is low for a carbon car. But it might be down to the dyno. If it reads that low on the MRC dyno I'd expect other issues such as a slight vac leak.
jasonhudds
Re: Power run
Post by jasonhudds » Tue Sep 13, 2016 5:25 pm
Cheers Mike for the reply
SuperNik
Re: Power run
Post by SuperNik » Tue Sep 13, 2016 9:38 pm
I think mine was around 370ps when first put on the dyno at mrc. After a carbon clean, stage 2 manifolds and stage 2 remap it made around 440ps.
I don't think 365ps is way off for a car in need of carbon clean.
06 Phantom black RS4 JCWeldfab exhaust, stage 2 inlet manifold, stage 2 remap
20" BBS CH-R's, H&R arb's and KW v3's and 034 adjustable top arms. Pioneer f77dab NOW GONE!!!
Other cars
65 palladium silver c63s estate, 2017 E63s on order
Former cars
64 white 991 turbo, 12 rosso nero 458, 64 white 650S, 06 Phantom black b7 RS4 saloon, 64 red golf gtd
Re: Power run
Post by MikeFish » Tue Sep 13, 2016 11:28 pm
No agreed it's not way off just a little on the low side.
Surrey Sam
Re: Power run
Post by Surrey Sam » Tue Sep 13, 2016 11:56 pm
390-370 - Car has some carbon issues.
370-360 - As above and potentially a vacuum leak.
Below 360 - Car certainly needs some attention.
mustdash
Re: Power run
Post by mustdash » Wed Sep 14, 2016 12:07 am
Mine made 370 on the MRC dyno. Carbon clean, stage 2 map and deflap and it made 424.
CURRENT: Montecarlo Blue Alfa Romeo Giulia Quadrifolglio, 2.9ltr bi-turbo, 510bhp
PREVIOUS: Volvo V60 Polestar, build number 149/700 worldwide - 3ltr straight 6 turbo. 350bhp remapped to 400bhp. Only one of 120 in the UK
PREVIOUS: Misano red B7 saloon, stage 2 map to 425bhp, manifold flap delete, KW V3 coilovers.
toyneg
Re: Power run
Post by toyneg » Wed Sep 14, 2016 9:30 am
My old car ran 343 on MRC's Dyno - I was told this was just Carbon build up by Doug but maybe there was something else they sorted as well - I paid for a stage 2 and CC and it then read 431 i think it was - the car felt way quicker after that.
rs user
Re: Power run
Post by rs user » Wed Sep 14, 2016 9:52 am
thing is to make sure it has good fuel,plugs and air/fuel filters-just the very basics make a good difference-particularly quality fuel for a good many miles beforehand to allow the car to run a decent amount of timing advance without detecting knock
jasonhudds
Re: Power run
Post by jasonhudds » Wed Sep 14, 2016 12:12 pm
Thank You all for the info
Users browsing this forum: AndyBrad and 110 guests
