After market exhaust info please
Grizwold
Post by Grizwold » Sun Sep 11, 2016 7:51 pm
Was be looking at getting a miltek in the near future , what I've read
These are the ones to have ?
I've got standard exhaust on my b7 rs4
What are your views is it worth the ££££
In return of what you get ,
& have you got to have a remap ?
Thanks in advance :thumbs:
Re: After market exhaust info please
Post by MikeFish » Sun Sep 11, 2016 8:00 pm
You've read wrong my friend. Milltek were the exhausts of choice about 5 years ago. Still the most popular exhaust but the current trend is for either modyfing the standard exhaust or a JC Weldfab. Do a search, there are plenty of threads on this topic already.
Frostie
Post by Frostie » Sun Sep 11, 2016 8:45 pm
I have a Milltek... it's ok but i wouldn't really recommend it... it drones badly under 2000 revs. my brother in law has done a centre box delete on his, and it sounds pretty much perfect.
2007 black RS4 saloon. Bilstein Coilovers, MRC Re-map, Miltek non resonated valved exhaust with de-cats, Gruppe-M carbon induction, JHM manifold spacers, Stage 2 manifold, cold air feed.
Grizwold
Post by Grizwold » Sun Sep 11, 2016 9:09 pm
Thanks guys , the standard one sounds fine but not on par with
Say amg or jag ???
Don't need no more Bhp just a better sound if that makes sence
FaisalJ
Post by FaisalJ » Sun Sep 11, 2016 11:01 pm
Modified OEM exhaust (pre-cats deleted, centre resonator replaced with X-pipe, valves stuck open):
https://youtu.be/E-Bm-gmEP6E
Full JC Weldfab system:
https://youtu.be/65SZXj4fTXA
2007 RS4 B7 Avant
audi_do_dat_den
Post by audi_do_dat_den » Mon Sep 12, 2016 1:08 am
Save yourself a wedge of money and start off with a centre resonator delete on your standard OEM system.
Sounds like the car should sound.... and your tailpipes will fit the rear end diffuser properly....
Then if you want more noise, gut your pre-cats.
Then if you're not entirely taken and you want to piss your neighbours off/set off car alarms, go and spend a fortune on a JC Weldfab or even go financially mental and have a Capristo fitted.
A20LEE
Post by A20LEE » Mon Sep 12, 2016 6:03 am
Milltek is the go too brand of the uneducated modifier.
rs user
Post by rs user » Mon Sep 12, 2016 1:59 pm
there was a miltek resonated sytem fitted to my rs4 when i bought it-i find it a pretty decent system,well enough made
fits well by the look of it and sounds nice- i bought the non res centre sections in case i fancied a change-but its loud enough for me at my age tbh
if it wasnt already fitted i would have simply left it with a standard system and possibly tried a centre section delete if it was easily changed back-but i dont think it is without a wee bit of work
ant@apautomotive
Trader (Expired)
Post by ant@apautomotive » Mon Sep 12, 2016 7:12 pm
Milltek no longer available.
They discontinued the RS4 B7 system last month. A few stockists may have some left.
AP Automotive - Parts, Servicing, Performance.
T: 01952 794024
E: info@apautomotive.com
W: www.apautomotive.com
Starry
Post by Starry » Mon Sep 12, 2016 8:22 pm
I find it strange that Milltek get such a slagging, I've had several on all sorts of cars and never had a problem. At the moment I'm running a non res valved Milltek with gutted pre cats.
With the flaps open its as loud as you'd want and, yes there is a little drone but you can drive around it. With the flaps closed it still sounds good, nice deep rasp but a fair bit quieter.
2006 RS4
Phantom black
Grizwold
Post by Grizwold » Mon Sep 12, 2016 8:31 pm
As above any idea on cost for this , seems a shame to ditch
A perfectly good exhaust system if nothing wrong with it when you can get this done ?
Frostie
Post by Frostie » Mon Sep 12, 2016 9:08 pm
Starry wrote:I find it strange that Milltek get such a slagging, I've had several on all sorts of cars and never had a problem. At the moment I'm running a non res valved Milltek with gutted pre cats.
Pretty much the same here.. except i have no cats, but as you say... it is possible to drive it in such a way that you don't hit the "drone" revs. other than that, it is a good system, although if it was down to me to spend £1500 on a Milltek, i think i would spend a bit extra and get the JC exhaust, or if not wanting to spend that sort of money, for the sake of around £80, do the centre box delete.
Post by MikeFish » Mon Sep 12, 2016 9:41 pm
Grizwold wrote:Modified OEM exhaust (pre-cats deleted, centre resonator replaced with X-pipe, valves stuck open):
Centre res delete about £100 to £200. Personally I wouldn't bother with x pipe, just go straight through.
Disconnect valves takes about 5mins and costs the price of 2 screws and 2 cable ties.
Gut pre cats is more about extra power than sound. It will add a little bit of sound but only worth doing as a power mod (rather than sound) as it'll be about £600 and will probably require a remap to get right of the error lights (although some people report having no errors).
FaisalJ
Post by FaisalJ » Mon Sep 12, 2016 10:58 pm
I paid £650 - but that was mostly because I had new downpipes made up, rather than gutting the precats on the existing ones.
From memory, £450 of the total cost was the new downpipes, and the remaining £200 covered the X-pipe (made with flanges so I could put the OEM centre silencer back if needed), and fitting the system (the car went to the exhaust shop without an exhaust after removing an aftermarket system, and the OEM system arrived later).
2007 RS4 B7 Avant
SuperNik
Post by SuperNik » Tue Sep 13, 2016 9:43 pm
Depending on whereabouts you are you could ask rs246 members that are local to you to give you a demo. There's quite a few with the above suggestions spread around.
06 Phantom black RS4 JCWeldfab exhaust, stage 2 inlet manifold, stage 2 remap
20" BBS CH-R's, H&R arb's and KW v3's and 034 adjustable top arms. Pioneer f77dab NOW GONE!!!
Other cars
65 palladium silver c63s estate, 2017 E63s on order
Former cars
64 white 991 turbo, 12 rosso nero 458, 64 white 650S, 06 Phantom black b7 RS4 saloon, 64 red golf gtd
Users browsing this forum: No registered users and 92 guests
