BOV and boost pressure
5.0 V10 50v biturbo - 571 bhp
Audi-RS6-R
Post by Audi-RS6-R » Sat Aug 27, 2016 12:46 pm
Hey,
I would know from the RS6 drivers with more then 800hp how much boost pressure you are running and which BOVs you are using to hold the pressure?
Greetings from Germany
rs6_sid
Re: BOV and boost pressure
Post by rs6_sid » Sat Aug 27, 2016 4:40 pm
Also interested in this and the location of them as if they are like the smaller Tfsi engine the diagram tears
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
TomRS
Post by TomRS » Tue Aug 30, 2016 4:06 pm
rs6_sid wrote:Also interested in this and the location of them as if they are like the smaller Tfsi engine the diagram tears
They are located under the air boxes.. the valve sits directly in the air box almost like a "once piece" setup
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
Audi-RS6-R
Post by Audi-RS6-R » Tue Aug 30, 2016 8:52 pm
So nobody?
Are all "over 800HP drivers" driving with the OEMs with no problems in holding pressure?
Trups
Trader (Expired)
Post by Trups » Tue Aug 30, 2016 9:11 pm
No issues with my 900 car. And I know it hasn't had an upgrade.
What's the issue with yours?
Audi-RS6-R
Post by Audi-RS6-R » Tue Aug 30, 2016 10:17 pm
I had issues...no boost over 1.4bar - I have now 2 Forges mounted...and running 1.7 - 1.8 bar
I was just curious, how others driving with more boost and OEM BOVs
rs6_sid
Post by rs6_sid » Wed Aug 31, 2016 12:08 am
does anyone know if they are a diagram style as at a guess they will degrade and would want changing if they are anything like other vag dv's
any part numbers ect ?
bmw e61 m5 saloon
s3 8p stage 2
Trups
Trader (Expired)
Post by Trups » Wed Aug 31, 2016 6:33 am
I'm going to book in for a map tweek soon so if your still unsure il be able to find out.
Will boost not go down to the turbo tho? Mine is the TTH 950. I'm sure I read before you had the TTh 850?
TomRS
Post by TomRS » Wed Aug 31, 2016 9:58 am
If your running a smaller turbo you may require more boost then the larger turbo... all the cars (that i know of) running 900+ are on stock BOV's running around 1.2-1.4 bar no more.
I wonder if more can be had from the stock turbo's applying this principal? then again you'd just end up with a crap droopy power curve so probably not worth it.
GBR1198
Post by GBR1198 » Wed Aug 31, 2016 8:43 pm
apparently the stock turbos at 800ps are pretty naff compared to a TTe at 800+ the power curve is completely different.
Clio 172 cup Track Car (AST 5200, cage, Carbon seats etc.)
2.0 Locost - Part finished
Old English White '68 4.2 E Type - current
Daytona B7 RS4 MRC Stage 2 - current
Sapang C6 RS, MRC Stage 2 - current
e91 Lci 335d - Gone
Daytona C6 RS6 Stock - Gone
Avis B5 RS4, Milltek, Brembo 18z and MRC 440ps and 660nm - Gone
DPB Mk5 Golf R32 - Gone
Audi-RS6-R
Post by Audi-RS6-R » Wed Aug 31, 2016 8:50 pm
Well - I am running the TTH850 upgrades with 1.7 @overboost
TomRS
Post by TomRS » Thu Sep 01, 2016 12:58 pm
GBR1198 wrote:apparently the stock turbos at 800ps are pretty naff compared to a TTe at 800+ the power curve is completely different.
Yeah i'd have thought so too, they are small turbos and wont flow well higher up the RPM.
I'll be going down the 3" downpipe (no engine removal) and a remap from MRC just to push power a little bit higher but nothing crazy, it'll be a long while before i upgrade any further!
rs6_sid
Post by rs6_sid » Thu Sep 01, 2016 7:20 pm
I was keen on the downpipes as well Tom but I was a bit put off by the fact of one of the rear studs can snaps it's an engine or job if it does as its inaccessible !
bmw e61 m5 saloon
s3 8p stage 2
Users browsing this forum: No registered users and 36 guests
