jon_v8 wrote:I have these springs on my avant running 20's with 265 30 20, the rears are as low as they will go and the fronts adjusted to suit, it's a bit of a pig of a job to fit them I left it to my local specialist as the drc with has to be recharged or my local specialist did it with the drc still attached. Comfort wise there is hardly any noticible difference to the ss+ set up.
That rear doesn't look like its as low as it will go, look at rear, you can only just see the top of the rear wheel.
You don't need to recharge the DRC when fitting as it can be done without disconnecting but it is recommended to check and adjust the pressure if lowering.
Don't forget to get a 4 wheel alignment done afterwards. Mine was wearing away the inside edge of the tyres due to the high camber . A set of adjustable top arms sorted that out.
I originally had a set of 265 tyres on but they obviously have a higher profile and are wider than the 255 so will theoretically ride better (I couldn't tell a difference) by also raise the car slightly. And have more clearance issues. I had to dial in a bit more rear camber to get some clearance on the rear but after switching to 255s I set the rear camber back to normal.
