Yellow Tyre Pressure Warning Light
RSCosworth
Post by RSCosworth » Thu Aug 18, 2016 8:47 pm
Sure this has been asked before but I couldn't find the answer after a quick search, got the yellow tyre pressure warning light come up on my dash despite the fact my tyres are all perfectly inflated but my question is, how do I reset the light?? Can't find my manual since moving house a few months ago :cry:
Mugello Blue B7 RS4 Avant, Black Optics, Buckets, FBSW, Carbon Inlays, Completely Standard
Previously owned:-
Nissan Sunny GTi-R
Renault Clio Williams
Ford Escort RS Cosworth
Renault Clio V6
Mitsubishi Lancer Evo 7
BMW M3 E46
irishmike
Re: Yellow Tyre Pressure Warning Light
Post by irishmike » Fri Aug 19, 2016 3:43 pm
Don't have the manual to hand, but from memory it is something like turn the ignition on, but don't start. Go to the menu and there should be a wheels option, set tyre pressure and that should fix it.
iduff
Post by iduff » Fri Aug 19, 2016 4:08 pm
I've just gone thru this myself.
First pass was to do the "Tyre Change" in the menu in the instrument cluster. That worked for a few minutes, then the pesky light returned.
VCDS said low signal (or similar nonsense), so I bought four TPMS wheel sensors on eBay (http://www.ebay.com/itm/261992884324) and had them swapped and tires re-balanced. Problem solved.
Seems like our cars are getting to the age where the batteries in the wheel TPMS sensors are dying of old age, and need to be replaced. HTH.
B7 RS4 Sedan, Phantom Black Pearl
Valved non-resonated Milltek with 200-cell DPs, and JHM tune, 10mm spacers
B8.5 Allroad, Monsoon Grey
CPO, stock
Former Quattros
B5 S4 Sedan, C4 S6 Avant, Type 89 Coupe Quattro, Type 44 Quattro Sedan
RSCosworth
Post by RSCosworth » Fri Aug 19, 2016 4:29 pm
Nice one cheers lads, will give it a go :thumbs:
Previously owned:-
Nissan Sunny GTi-R
Renault Clio V6
BMW M3 E46
BaCoN
Post by BaCoN » Mon Aug 22, 2016 4:50 am
This ---> "Tyre Change" in the menu in the instrument cluster
I am not looking forward to batteries dying!
ashleyg
Post by ashleyg » Mon Aug 22, 2016 1:55 pm
My TPMS batteries went flat, I turned the TPMS off using VCDS until I'm ready for a set of tyres :bigblink:
rs4pat
Post by rs4pat » Mon Aug 22, 2016 4:38 pm
where do you buy the VCDS from?
Users browsing this forum: 22B and 145 guests
