EPC issue
5.0 V10 50v biturbo - 571 bhp
rtd
EPC issue
Post by rtd » Wed Aug 03, 2016 7:13 pm
Folks when car is above 50 (and normally when in S mode) when I accelerate hard I get the EPC light come on with warning not to go over 4K revs this has happened a few times now. Anyone experienced anything similar?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Golfather
Re: EPC issue
Post by Golfather » Wed Aug 03, 2016 10:58 pm
VCDS will tell you what it is, most likely a sensor somewhere needs replacing.
Had something similar on a S4 V6T, needed a new oil pressure sensor.
kent_andy
Re: EPC issue
Post by kent_andy » Thu Aug 04, 2016 3:51 pm
have you got ceramics? that could be the reason......
2017 911 991.2 Turbo S
2007 Audi A3 2.0T Quattro
rtd
Re: EPC issue
Post by rtd » Thu Aug 04, 2016 3:52 pm
But they aren't applied when the light comes on? Plus they've been coded in.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Mr V10
Re: EPC issue
Post by Mr V10 » Sat Aug 06, 2016 4:27 pm
Yes, I had this. New throttle body, as MRC suspected throttle position sensor which is built into the throttle body, that didn't work, next was some wiring to the ECU, tested hard on dyno, all ok, soon returned... It will occasionally come on again on hard throttle, need to have it back in but been too busy and only done 214 miles in it since Dec, so never been a priority.
rtd
Re: EPC issue
Post by rtd » Sun Aug 07, 2016 4:34 am
Thanks V10 will also investigate this.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
discostu49
Re: EPC issue
Post by discostu49 » Mon Aug 08, 2016 11:38 pm
I just discovered tonight there is epc sport mode ?? And if held epc goes off anyone know what epc sport mode entails
IanH755
Re: EPC issue
Post by IanH755 » Tue Aug 09, 2016 9:56 am
Stu - Do you mean the "ESP" (traction control) button as RTD is talking about the EPC (electronic power control warning) which is a dash warning light and a message displayed on the DIS screen telling you of a problem with the car?
If it's ESP you're are asking about then a short press is supposed to "switch off" the traction control system (TCS) only it doesn't fully, it just allows a lot more wheel spin before activating.
If you hold the button down for 3+ seconds it switches the TCS off (completely off this time) and also the ESP (electronic stability program) gets switched off too. The ESP brakes the rear wheels individually to stop the back end moving about under heavy acceleration and braking.
Personally I never found 730hp to be enough power (outside 1st gear or the wet) to cause the TCS to activate when accelerating full throttle in a straight line. However at 900+ a 2nd-3rd full throttle change (with a short press to switch TCS off) still causes the TCS to reactivate when accelerating in a straight line. I found that with a long press the combination of TCS and ESP both being switched off removes *all* TCS (unlike a short press) and you can have full throttle changes with a touch of wheel spin with no problems.
discostu49
Re: EPC issue
Post by discostu49 » Tue Aug 09, 2016 12:49 pm
Yes Ian I was meaning the traction control esp lol many thanks dude
Users browsing this forum: No registered users and 39 guests
