Has anybody had any issues with loose heat shields around the exhausts? The 4 sections over the rear backboxes have perished where the nut/washer goes through. I've tried using a larger washer to hold them together, but the studs have lost their threads due to the rust.
Has anybody got any work arounds? I.e riveting them to the underside? Or shall I just stump up and buy new heat shields. Any idea of the costs (I presume there will be some RS tax applied?)
Exhaust heat shields
Re: Exhaust heat shields
Sadly it's common on most cars due too the aluminium heat shield touching the steel fixing . Causes galvanic corrosion. Really wouldn't recommend drilling and riveting the underside . I'd just be looking too replace the Shields myself. As for the fixings u can either grind them off and tac weld a new stud on or use a riv nut insert and bolt them on .
Cheers Al
Yeh, mine are going the same way too.
Right side (up to VIN 4B-3-904500): 4b3804172. Left side 4b3804171. Later models have a different part, add A to the end.
A quick look at a german website:
WAERMBLECH
OE-Nr: 4B3804171
87.60 EUR
WAERMBLECH
OE-Nr: 4B3804171A
198.90 EUR
WAERMBLECH
OE-Nr: 4B3804171
87.60 EUR
WAERMBLECH
OE-Nr: 4B3804171A
198.90 EUR
Users browsing this forum: Google Adsense [Bot] and 117 guests
