gdavison wrote:Back when I had mine I did a post of the easy ones on the "other forum"
http://audisrs.com/Things_to_play_with_ ... 28108.html
I had done the VIM, Hidden menu, Battery Status .. all did what they where supposed to do
Car dead
Re: Car dead
If you have a VAG-Com cable, do the mod the MMI to add in the battery gauge as well .. useful for keeping an eye on the state of your battery
Re: Car dead
Battery status when I was driving a week or so ago showed the battery status as 100%.
Daytona Grey C6 RS6 Avant
Ebony Black C5 RS6 Plus - Gone
Re: Car dead
SHE'S ALIVE!!!!
Just need to keep an eye on the battery's voltage now to ensure it doesn't drop too much.
By the way, it's an absolute ballache having to climb through the front into the boot and installing it from there.
Re: Car dead
Yup mine ran out of puff fitting Trups light kit. I did have the radio on to hide my swearing as the puddle light connectors disappeared into the door never to be seen again. New battery sorted everything out
Re: Car dead
Ha, the joys of owning cars!!skirs6 wrote:Yup mine ran out of puff fitting Trups light kit. I did have the radio on to hide my swearing as the puddle light connectors disappeared into the door never to be seen again. New battery sorted everything out
Ski, where did you get your alu trim wrapped please and what sort of cost was it if you don't mind me asking?
Re: Car dead
It was totally dynamic in Redhill roughly £400 for roof bars window surrounds door handles and front grille
Re: Car dead
I followed these instructions to get the battery charge level on the MMI and it worked fine:
https://youtu.be/zMTtglRmrww
I also enabled the oil level indicator using the same method but whilst it shows on the MMI it doesn't work so no idea how to set that up.
Current:
Former:
2016 R8 V10 Plus.
2019 E63s AMG 4Matic Estate.
2017 BMW M3 Competition Pack.
2015 A45 AMG.Overrated POS.
2016 C7 RS6 Panther black.
2006 BMW Z4M Roadster.
2004 Alpina Roadster.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Re: Car dead
Brilliant, thanks mate.skirs6 wrote:It was totally dynamic in Redhill roughly £400 for roof bars window surrounds door handles and front grille
Re: Car dead
Yeah it's easy enough to enable but mine was reading 100% a few days before it decided to pack it's bags!stevo55 wrote:I followed these instructions to get the battery charge level on the MMI and it worked fine:
Re: Car dead
Try the Army method-hit it as hard as you can with something heavy
Current:
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Former:
2016 R8 V10 Plus.
1994 E34 M5 Saloon
Re: Car dead
Seems legit.....stevo55 wrote:Try the Army method-hit it as hard as you can with something heavy
Re: Car dead
Stupid question but how do I check the engine oil level??
I would look in the handbook but it's at home!!
Re: Car dead
Once the engine is upto temp (95'c+) and you're on level ground, switch off the engine and check the dipstick about 1 minute later.
Re: Car dead
Thanks Ian. I didn't even know where the dipstick was until I used my nugget.
I thought I'd read you can also check the oil level through the MMI?
Another question that's slightly off topic but when updating the MMI software, do you need to unpack the iso files so the folders are all shown?
Re: Car dead
I've not updated mine using a USB cable, I put the CD's in the CD changer and let the MMi update itself and then ran out of battery juice and had MRC do it instead (took 3+ hours!).
Users browsing this forum: hartley1967 and 35 guests
