Fuel pump options A6 - S6 - RS6
Ajc
Re: Fuel pump options A6 - S6 - RS6
Post by Ajc » Wed Jul 13, 2016 10:30 am
Just as a side note , Mine had a misfire under boost shortly before one of my turbos sh*t it's self . You say you've checked the requested and actual boost ? .
Cheers Al
VETRA
Post by VETRA » Wed Jul 13, 2016 10:59 am
Going for a test-ride now.
will come back with test results.
Ajc wrote:Fuel pressure regulator, N75 , Diverter Valves. ? All reasonably priced and worth changing I would suggest.
Also worth checking your injector spray patterns
Diverter Valves?
These?
ready to change them all.. ))
Ajc
Post by Ajc » Wed Jul 13, 2016 12:53 pm
No the recirculating dump valves. They are plumbed in too the charge carrier with vac pipes going too them . Marked as DV's on your pic .
Cheers Al
Post by Shoppinit » Wed Jul 13, 2016 5:25 pm
If you suspect fuel starvation then you should log your lambda values while driving and see what happens when the problem occurs.
Also, as already said, log the requested and achieved boost.
Aren't there any DTCs stored?
Users browsing this forum: Shoppinit and 86 guests
