The engine does not start. I get a good start rpm and fuel pressure. But the injectors don't fire. No fauldcodes in the ecu.
I checked the fuses and they are all oke. Also measured the voltage on all fuses and noticed 1.6volt and 2.1volt on the ECU fuses number 29 and 32 at the side of the dash
This is only when the ignition is on when cranking the engine it is around 11Volts.
Looked at the engine wiring but cant see why I have 1.6 and 2.1 volts on the fuses when ignition is on but you never know right?
So is there anybody ho can measure the voltage on fuse 29 and 32 when the car is on ignition to see what is normal?
It would really help me. I have a appointment on Monday for the car to go to the detailer
