420mm ceramic brake pistons
5.0 V10 50v biturbo - 571 bhp
Audi-RS6-R
Post by Audi-RS6-R » Tue Jul 05, 2016 11:11 pm
Hey,
I guess my pistons of my ceramic callipers are not movin correctly anymore...they are very rusty :cry:
Somebody knows if there is a chance to get the pistons of the callipers to buy?
Greetings
IanH755
Re: 420mm ceramic brake pistons
Post by IanH755 » Wed Jul 06, 2016 12:31 am
The pistons need a special removal tool according to Alcon (https://www.alconkits.com/tools-and-sup ... ool-detail) and you need to know if the pistons are Aluminium or Steel and their size too.
As the Calipers are Audi OEM, Alcon may not give you any information on the piston as Audi hold the rights to all the info (same issue I had finding Brembo info out).
Sorry thats not a lot of help but it may be better just to give them to a refurbishment company instead and let them deal with Alcon.
rs6_sid
Post by rs6_sid » Wed Jul 06, 2016 10:08 am
You would be able to do them your self if the seals are good and you have a fair mechanical know how , get the Pistons cleaned up chemically and re coated as I imagine they have some kind of finish on them
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
Golfather
Post by Golfather » Wed Jul 06, 2016 11:30 pm
I have a brand new set. PM sent.
However check your seals first - there was a recall to replace the seals on early calipers.
Audi-RS6-R
Post by Audi-RS6-R » Thu Jul 07, 2016 12:36 am
@Golfather...PM sent
I think the seals must be okay...I don't loose brake fluid...and according of my car history, they changed and replaced the disks & callipers twice :bash:
TomRS
Post by TomRS » Fri Jul 08, 2016 7:15 am
Callipers changed twice? holy cow... must be something where you live that doesn't agree with your pistons.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
Audi-RS6-R
Post by Audi-RS6-R » Fri Jul 08, 2016 7:40 am
Well, I don't live in the Sahara and neither in the North Pole :thumbsdown: :o
TomRS
Post by TomRS » Fri Jul 08, 2016 7:47 am
Audi-RS6-R wrote:Well, I don't live in the Sahara and neither in the North Pole :thumbsdown: :o
hahaha! terrible that though, two replacements... and now the 3rd set gone? surely there's something a miss?
Quattro_RS6
Post by Quattro_RS6 » Fri Jul 08, 2016 8:22 am
I guess they use salt on the roads during wintertime in Germany as weell? :)
The pistons are actually stainless steel, but it's the backing plate to the brake pad which corrodes and leave rust around the pistons. Also, even if the pistons are stainless, they will get dirty, pitted and eventually start to restrict free movement.
The problem with the Alcon 8 piston calipers are that they do not have dust seals. It may be that they have internal dust seals, but still, they are not as good protected as the normal design found on Brembo and standard calipers.
Shpend; i think you have to disassemble the caliper, clean the pistons or buy new ones, and reassemble with new seals and grease. New pads is also wise to install looking at your pictures.. :)
I add a couple of pictures of my own calipers before they were sent to refurbishment. You can easily see the pitting on the pistons, but if they were not stainless steel they would have been very corroded and completely brown. (The calipers are also yellow/gold in colour, but that's due to heat input on last years track day :bash:
2013 Audi Q7 3.0 TDI - Family car
2008 Audi RS6 Avant V10 TFSI - Phantom black, ceramics, ACC, softclose, 21" MTM, MTM springs, MTM Cat back.
2003 VW Bora 1.9TDI Highline - Daily beater
1991 VW Golf cabriolet G60 & 1963 Ragtop T1 beetle, forever lasting project (started in 1998)
X 2007 Audi S8 V10 // 1998 Audi A6 2.5TDI Quattro // 2001 Audi RS4 MTM // 2000 Audi A6 2,7 BiTurbo Avant // 1996 Audi RS2 // 1991 Passat Syncro G60 Turbo
IanH755
Post by IanH755 » Fri Jul 08, 2016 8:49 am
Quattro_RS6 wrote:The problem with the Alcon 8 piston calipers are that they do not have dust seals.
It might be because ceramic brakes get so hot (900'c) that they can't use external dust seals as they would melt and have internal seals only.
TomRS
Post by TomRS » Fri Jul 08, 2016 9:17 am
Seems legit ian....
Although it seems odd that they would design something to be so... "bad" but again saying that ceramics are still very much a race car type addage and in those enviroments they are not suspect to salt/dirt.. they are also usually stripped and cleaned after every event.
Might be worth stripping down the calliper and cleaning it and the pistons every 5000 miles/ 6 months?
IanH755
Post by IanH755 » Fri Jul 08, 2016 9:29 am
It seems to be an issue with Alcons "early" pre 2006 designed OEM calipers. The newer C7 Brembo Ceramic calipers and newer aftermarket Alcon ones all come with dust seals now (no idea what it's made of).
Quattro_RS6
Post by Quattro_RS6 » Fri Jul 08, 2016 9:31 am
That could also be a reason for it, off course. Alcon is one of the leading provider of racing calipers, so i guess they know what they are doing :)
I actually burnt the rubber dampening plate on the pads last year at a track day..
Quattro_RS6
Post by Quattro_RS6 » Fri Jul 08, 2016 9:45 am
IanH755 wrote:It seems to be an issue with Alcons "early" pre 2006 designed OEM calipers. The newer C7 Brembo Ceramic calipers and newer aftermarket Alcon ones all come with dust seals now (no idea what it's made of).
Here's some interresting reading: https://www.essexparts.com/cp9668-trail ... t-anodized
It may be that the C7 ceramic brakes with Brembo caliper is less track firendly, but more all year around-friendly.
IanH755
Post by IanH755 » Fri Jul 08, 2016 10:46 am
The Radi-Cal Calipers in the link above are what TomRS has had fitted (slightly different model) and what I'm getting fitted this month :D
Users browsing this forum: No registered users and 136 guests
