Steering wheel whine
rs4uk
Post by rs4uk » Sun Jun 19, 2016 9:59 pm
Hi guys
I noticed that on my rs4 if I full lock the steering in either direction I get a whine, does anybody else get this? Is it normal?
Only get the noise on full lock
Shinobi675
Re: Steering wheel whine
Post by Shinobi675 » Sun Jun 19, 2016 10:02 pm
Are you sure it's the steering wheel? I get something very similar and comes from slightly to the left.
I finally realised it was only when the wife was in the passenger seat though.
Post by MikeFish » Sun Jun 19, 2016 10:06 pm
Check your power steering fluid level.
RichieRS
Post by RichieRS » Sun Jun 19, 2016 10:07 pm
Shinobi675 wrote:Are you sure it's the steering wheel? I get something very similar and comes from slightly to the left.
Haha. Excellent
I presume you've checked your power steering fluid level?. Have had cars in the past that have been noisy on full lock when the fluid is low
RichieRS
Post by RichieRS » Sun Jun 19, 2016 10:08 pm
Mike beat me to it :mrgreen:
toyneg
Post by toyneg » Mon Jun 20, 2016 2:02 pm
rs4uk wrote:Hi guys
Every RS4 i have heard makes a squeal noise when on full lock, mine certainly does too
C5ARK_RS4
Post by C5ARK_RS4 » Mon Jun 20, 2016 5:30 pm
As Mike said. Check power steering fluid level. Mine was doing it and a very small top up cured the problem.
ewand
Post by ewand » Wed Jun 29, 2016 11:27 am
You might want to flush the PS fluid too. viewtopic.php?f=35&t=114100
8V S3 cab - Ara Blue
Lotus Evora 400 - Racing Green
Ex owner B7 RS4 - Mugello Blue, B8 S5 Cab - Sprint Blue, D3 A8
audi_do_dat_den
Post by audi_do_dat_den » Wed Jun 29, 2016 12:19 pm
I get a squeal when on full lock against the stops.... it doesnt make any noise at any other time.
Initially i thought it was a belt slipping but since the power steering is directly driven from the PTO gears, ive put it down to an ageing relief valve.
My mates RS4 makes exactly the same noise so im not bothered by it.
Might do a flush but its tickety boo otherwise.
hector8
Post by hector8 » Thu Jun 30, 2016 3:32 pm
This happened me a few weeks back. Was the fluid level. Very small top up needed.
Remember when measuring the level the dip stick is not to be screwed down, just measure when unscrewed. Only takes a second or two of light pour to top up.
harding
Post by harding » Sat Jul 02, 2016 3:22 pm
Ive had this for 3 years on my car. Where do i top up the fluid??? Need to try!
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
Post by MikeFish » Sat Jul 02, 2016 9:57 pm
harding wrote:Ive had this for 3 years on my car. Where do i top up the fluid??? Need to try!
The Power steering fluid reservoir is on the right hand side of the engine bay in front of the windscreen washer resevoir. There is a cut out for it in the plastic engine cover.
harding
Post by harding » Sun Jul 03, 2016 11:33 am
Thanks Mike!
And how much should i put in there? Will stop by audi in a bit and get some.
Audi RS4 Avant
Users browsing this forum: Quinten, Zyox and 123 guests
