Gear knob upgrade
Re: Gear knob upgrade
Looks great! Definitely something I'll be doing.
- Audi-RS6-R
So how hard is this to do?
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2017 Mercedes E63S W213 1033/1400nm
2013 Mercedes E63S W212 740/1200nm
2010 Nissan GT-R SVM 680R
2010 RS6 C6 Avant Stage 2 730/1088nm
Read the guide, have to tools ready. 20-40 mins. You can do it.
Am i being thick i cant find the guide?Ungjaevel wrote:Read the guide, have to tools ready. 20-40 mins. You can do it.
I can't either
The procedure is called 'Heat & Twist' and is common among all Audi with the auto box.
Essentially, the procedure is lifting off the old gear knob to expose the plastic shaft that it sits on. Because the original shift button is on the side, and the new one is at the front, the plastic shaft is facing the wrong direction in relation to the new forward facing shift button. Fortunately the shaft is made of soft plastic and can easily be heated-up and twisted until it faces the right direction. Sounds scary, but is quite straightforward.
Full procedure guides here:
http://www.audizine.com/forum/showthrea ... -Knob-swap
http://forums.vwvortex.com/showthread.p ... nob-in-Mk4
The only advice is to go slow and take your time. Apply heat progressively and not too close, or you risk burning/melting the shaft.
Good luck
Good luck
C6 RS6 Plus with a few sensible mods...
The metal clip that gets replaced with a zip tie in the first link can be replaced with a small CV joint boot clip, I fixed the gear knob in my daughter's boyfriend's Golf a few months back with a clip that was left over from another job.
Cheers Ceveman73, that was the missing jigsaw in the puzzle, really appreciate it.
Cheers Jum for the tip!
Just to revive this...
Will any RS shifter from the same era fit? (specifically the gaiter)
Answered my own question here. The shift knob and gaiter from a B8 RS4 fit perfectly, the aperture is exactly the same size. The only difference being the plastic trim that the leather gaiter is stapled to - the clips are in a different position. I carefully removed the staples and swapped them over and it's all done, an easy job to do.
(I preferred the gaiter from the RS4 as the stitching is light grey to match the stitching on my seats)
Users browsing this forum: alex.r and 64 guests
