New User: Hello from Germany
5.0 V10 50v biturbo - 571 bhp
rs6_sid
Re: New User: Hello from Germany
Post by rs6_sid » Wed May 25, 2016 5:48 pm
Any more info on the air boxes ? I feel this is a big area for improvement on our cars
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
Stef92
Post by Stef92 » Fri May 27, 2016 8:43 am
Is it possible to have the address of the company which has prepared your steering wheel ?
Audi RS6 C6 Exclusive black-brown
Nappa leather and Ceramic :)
Audi-RS6-R
Post by Audi-RS6-R » Fri May 27, 2016 10:28 am
@rs6_sid - I just know the airfilters are now vertical not horizontal in the box...
@Stef92 - yes of course... https://www.facebook.com/Inc-Lederdesig ... 8798703516
Trups
Trader (Expired)
Post by Trups » Fri May 27, 2016 12:03 pm
more info on you engine, who mapped it, what other mods to get that power.
it looks great with the black optics now.
Audi-RS6-R
Post by Audi-RS6-R » Fri May 27, 2016 12:15 pm
@Trups... Thank you... ;)
Mapped by THT - Performance here in Germany...a old friend of mine and just 100km away ;)
I wrote about the mods some postings ago...
Audi-RS6-R
Post by Audi-RS6-R » Fri May 27, 2016 12:22 pm
A small clip of acceleration...with ESP on - so not full of torque...
Trups
Trader (Expired)
Post by Trups » Fri May 27, 2016 8:36 pm
Did you not need to upgrade your box?
And light errors, can I help? Lol
Audi-RS6-R
Post by Audi-RS6-R » Fri May 27, 2016 8:43 pm
@Trups...I sent my headlamps to a company to be polished, new reflector etc. After I get them back and remounted them, I get this errors... the LEDs and the dynamic light on the left are not working. The company told me, it happend on the shipping way...a connector ist probably off... so I have to send them back to fix this :(
The gearbox is still OEM, I was 1 month ago at ZF (company which build this gearbox) and do a oilchange front and back + new Multitronic
The torque is limited by gearmapping...
Trups
Trader (Expired)
Post by Trups » Fri May 27, 2016 8:51 pm
Check the black adaptive box if you can, if you have narrowed it down to the left swap the boxes over, the adaptive ballast on the plastic body of the light closest to the grill and not are not the ones under.
Did you start the car at all while the headlights where out? Have you tried to clear the codes I take it?
On your graph it shows your over 1200nm, was that before it was limited?
Trups
Trups
Trader (Expired)
Post by Trups » Fri May 27, 2016 8:52 pm
Also, did they open the lights up then?
Audi-RS6-R
Post by Audi-RS6-R » Fri May 27, 2016 8:57 pm
Yes they did...without cutting in the housing...
Before & after....
Audi-RS6-R
Post by Audi-RS6-R » Fri May 27, 2016 9:03 pm
@Trups... It was limited on 1240Nm - but I went 2 day ago again and let it down to 1150Nm
I just had ignition on to delock the steering wheel while the headlamps were out..I cleared the codes many times...no luck.
When I turn the light on, the right LEDs just flash for a second on....the left don't work.
Do I have to open the headlight housing for your recommendation?
Trups
Trader (Expired)
Post by Trups » Fri May 27, 2016 9:08 pm
So the removed the projectors without splitting the headlights?
And that's some bad pitting/burnt bowl, is that a before and after? They had one re chromed? I had mine re chromed and for the work that went into it vs the results I won't be offering the re chrome service, I have adaptor brackets that the whole projector can be changed out.
It does look like its took a knock but the power cable for the drl is under the inner fog light reflector so unsure why you drl could be an issue. Hope they sort it for you.
Audi-RS6-R
Post by Audi-RS6-R » Fri May 27, 2016 9:13 pm
They opened the headlight completely, but without cutting in the housings like many people here in Germeny does...
They do not re-chrome - these are new Hella-Reflectors...and that one on the pic is my old reflector...
Yes...I hope so - they will all fix again like it was...
Trups
Trader (Expired)
Post by Trups » Fri May 27, 2016 9:16 pm
Ahh ok, I can get into the housing now via the sealant channels.
That's good they put the new chromed bowls. Can you see the difference in output? I have never seen a burnt bowl on a C6 and I've worked on around 10 sets.
Users browsing this forum: Google Adsense [Bot] and 68 guests
