Yes, I deserve it.
Ok, I think I've gotten to the bottom of it now. One Andy w called them resonators, the other Andy w called them secondary cats. I believe they are indeed secondary cats hence why you can remove them with no fault lights or MOT issues later down the line.andywaddy wrote:Basically what I've done (and what you're going to do) is the same as what a non-resonated Milltek is, bar the rear back boxes which we've kept as stock. There are no sensors around the questionable resonators so I assure you no issues will occur - and I've never had any issues with Audi whenever it's been in for work.MikeFish wrote:Looking at photos of aftermarket cat back systems it is not entirely clear but I think you are right about them being resonators. I'll get them chopped out too then! Thanks
Not a problem my friend, happy to help. Let me know how you get on!
Yes they are definitely secondary Cats. All the R8 aftermarket systems delete the secondaries and I never had any smoking or any noticeable difference. Removing them will provide a little less resistance and noise suppression I believe.MikeFish wrote:Ok, I think I've gotten to the bottom of it now. One Andy w called them resonators, the other Andy w called them secondary cats. I believe they are indeed secondary cats hence why you can remove them with no fault lights or MOT issues later down the line.andywaddy wrote:Basically what I've done (and what you're going to do) is the same as what a non-resonated Milltek is, bar the rear back boxes which we've kept as stock. There are no sensors around the questionable resonators so I assure you no issues will occur - and I've never had any issues with Audi whenever it's been in for work.MikeFish wrote:Looking at photos of aftermarket cat back systems it is not entirely clear but I think you are right about them being resonators. I'll get them chopped out too then! Thanks
The milltek full system removes the primary cats in the down pipes, the places the sports cat (assuming you don't go cat bypass) under the car where the secondary cats normally live. Hence why they state you need sensor extension wires (cos they've moved the main primary cats from the down pipe position to underneath the car).
The milltek cat back system removes the secondary cats too.
So the question is, how restrictive are the secondary cats? Is there any noticeable power gain once they have been removed? Or do they only work when the engine is cold? And will I get a smokey exhaust when 1st starting the engine?
Lowered, check. Illegal number plate, check. Aftermarket exhaust, check. Amps, check. Sub in boot, check. Go...MikeFish wrote:Earlier in the week I added an amp and sub to the boot. Makes a huge difference.
That would be a length of Phoenix Gold subwoofer speaker cable. It also doubles up as tie cord for his b1tches.Surrey Sam wrote:![]()
I was wondering why Mike had a skipping rope in the boot?
