Hello guys, I might have found a solution :
Is it possible to remove the bolts that hold this part (the one that the VSS goes into and is out on the second picture) and turn it a bit ?
Credit for the picture, goes to (
http://www.motorgeek.com/viewtopic.php?f=15&t=46685)
I think this might be possible, only problem I see is the oil seal. I'm wondering if the oil behind the driveshaft is geabrox oil or some sort of differential oil ?
Because if the seal needs replacing, I'll have to take the other driveshaft out to take the part out and that will be another job keeping in mind the limited access ...
Thanks for your
@ bam_bam : you are right, I'm begining to see that almost everyjob, requires to take the engine out, it's irritating ...
@ Shoppinit : I can keep the car and still be happy. For that I'll just have to turn the engine, and I might forget all of the problems, efforts ...
