IanH's C6 RS6 - 925hp & 1150nm - Updated 06 Jun '25
Re: My 900+ spec
Ian - wow. Simply, wow.
Just add the ceramics and this Death Star is complete!
Awesome work.
Awesome work.
Gone but never forgotten:
TomRS
Re: My 900+ spec
Think he's going to run the same setup as i am 410mm Steels... as without going into way loads of detail the Audi Ceramic compound is no good for track use.neilparf wrote:Ian - wow. Simply, wow.
Awesome work.
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2010 Nissan GT-R SVM 680R
- Shinobi675
- 5th Gear
Re: My 900+ spec
I'm so happy you boys are around
the laws of physics argument about ceramics always annoyed me.
Tyre grip is the limiting factor so steals can clearly stop as powerfully as ceramics... The weight is the benefit. Bit that 410 setup is pretty light unsprung weoghtx
Re: My 900+ spec
The issue is in what conditions each application is used. There are pros and cons for both material types.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Re: My 900+ spec
Absolutely true there Gurj!
To prevent derailing the thread into a brake debate I'd suggest a separate "Audi OEM Ceramics vs Steel" thread be made.
TomRS
Re: My 900+ spec
Create one? its about time we put this to bedIanH755 wrote:Absolutely true there Gurj!
Re: My 900+ spec
If anyone is interested in my history with the C6 I've kept a "Car Diary" over on Pistonheads with everything I've done since the day I bought her and it'll be kept up to date with constant updates - http://www.pistonheads.com/gassing/topi ... &t=1530059
Re: My 900+ spec
Ian - hats off to you Buddy - 750 aint cutting for me anymore...im off to rob a bank coz I need some of that!!!
One question re water meth - did you install this at stage 2 or after - any noticeable improvements as that's my realistic short term upgrade ? living In Dubai I see this as a no brainer..
Thanks in advance Lee
Daytona Loon - Stage 2 + - No F/R Cats - 3" MTM Valved Zorst - AP F&R Discs DS2500 Pads - Kw v3 Coilover - 10mm Spacers - TRUPS LED etc...
Re: My 900+ spec
It was part of the stage 3 upgrade so I've no idea what it'd be like for stage 2 I'm afraid.
Re: My 900+ spec
Water meth for stage 2 give you the edge only if you map it in. I had it when I had stage 2 but not mapped in. Just the advantage of running cooler without additional power was good enough for me. With hybrids, it is a different story and is a MUST because you are fighting with massive heat soaks especially if you are running OEM or not so efficient intercoolers.
Re: My 900+ spec
Thanks Ian / Classba I'm going to map it in so will hopefully feel the benefit plus it will make me feel better with outside temps in the high 40s over the coming months...
Re: My 900+ spec
900PS + 2tonnes with steel brakes is not somewhere I would want to be...
Re: My 900+ spec
+1 Here we go again lolHYFR wrote:900PS + 2tonnes with steel brakes is not somewhere I would want to be...
Re: My 900+ spec
This man loves to write lolIanH755 wrote:If anyone is interested in my history with the C6 I've kept a "Car Diary" over on Pistonheads with everything I've done since the day I bought her and it'll be kept up to date with constant updates - http://www.pistonheads.com/gassing/topi ... &t=1530059
Re: My 900+ spec
Yep he does so - but is respected and appreciated by many users who value his opinion and honesty in what he says and does.classba wrote:This man loves to write lolIanH755 wrote:If anyone is interested in my history with the C6 I've kept a "Car Diary" over on Pistonheads with everything I've done since the day I bought her and it'll be kept up to date with constant updates - http://www.pistonheads.com/gassing/topi ... &t=1530059
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Users browsing this forum: No registered users and 9 guests
