Transmission fluid drip
- 1st Gear
Hi. I've had a very slow drip of fluid last few weeks. I thought it was just AC discharge, but it turns out it's transmission fluid. Maybe two-three drops per week when the car is driven, no drips when the car s parked. It's center of the car, just behind the front wheels. I don't have a lift so I can't get a good look, but what are common leak points in that area?
2003 RS6 Avant, Daytona grey
2012 Toyota GT86
2014 Toyota Prius Plus 7
2012 Toyota GT86
Re: Transmission fluid drip
The only real places for the oil to leak are from the unions and pipes that link to the cooler, the side and rear flanges (although these have their own diff oil in them - so it could be those leaking instead - rear is fairly common) or the sump plug/filler or out gasket. The main sections of the gearbox casing could also leak, but it'd be pretty rare for those to leak.
It'd be hard to tell if the front inner flange (where the torque converter joins to the engine) is leaking because oil could also leak out from the engine to that area too.
Check the hoses first and go from there. Has it ever had a gearbox oil change?
Daytona RS6 Avant
- 1st Gear
It had a change 120.000km ago, it's due another one at the next service (242.500) now.
I'll check the hoses for the cooler, that sounds easier than a main shaft seal.
2012 Toyota GT86
2012 Toyota GT86
Sounds more like the transfer box flange oil seal. Common fault.
- 1st Gear
Hiw difficult is that to fix?
2012 Toyota GT86
2012 Toyota GT86
Not too bad. Check the FAQ for a good DIY.
I did it the other day, did it on a ramp in about an hour, and was taking it easy. Didn't come across any problems either.
^ Apart from when it starts leaking again in a weeks time
Daytona RS6 Avant
Fingers crossed it doesn't , only pushed it in the 6mm or whatever the FAQ saysNobby wrote:^ Apart from when it starts leaking again in a weeks time
- 1st Gear
Sounds good. I'll have a look when I do the brakes and bearing that she also needs.... Ad the brake hose... And the DRC lines.... And the new battery... *sigh*
2012 Toyota GT86
2012 Toyota GT86
I have a set of brand new genuine exhaust clamps if you need them
But I guess your not in the UK, so doubt it will be economical..
- 1st Gear
Yeah, in Norway, so I'll source them locally if needed. She needs some love in many areas, sadly.
2012 Toyota GT86
2012 Toyota GT86
- audi_driver79
Back in 2012 I had a small leak from the gearbox which never reappeared after getting it serviced fingers crossed.
C5 RS6 Avant Mugello Blue, Original Springs.
1997 Audi Cabriolet 1.8 for when its Sunny!
2001 A2 1.4tdi 75bhp.
- 1st Gear
Had a look yesterday, and there's transmission fluid everywhere. Seems to be the flange seal, and the shaft is throwing the oil everywhere. Left side. Can anyone confirm it's 01L 409 399 that goes in there?
2012 Toyota GT86
2012 Toyota GT86
Which shaft? Drive shaft to front left wheel?
Users browsing this forum: B_O_N_K and 73 guests
