Should I move her on...
5.0 V10 50v biturbo - 571 bhp
leehewitt
Re: Should I move her on...
Post by leehewitt » Mon Apr 25, 2016 10:52 am
As per the ebay link ones (https://www.ebay.co.uk/ulk/itm/201415985590) has anyone experienced the 3m stickiness as an issue ? - reason I ask is that im based in Dubai and the temps of the car if left outside might be an issue?
Daytona Loon - Stage 2 + - No F/R Cats - 3" MTM Valved Zorst - AP F&R Discs DS2500 Pads - Kw v3 Coilover - 10mm Spacers - TRUPS LED etc...
IanH755
Post by IanH755 » Mon Apr 25, 2016 1:35 pm
I use 3M 2mm double sided Foam cut to shape rather than the supplied 3M sticker (which I removed as I think it's too thin) and I've had no issues at all.
I've just ordered the silver set above to replace my CF set as, like TomRS mentioned, they work but the looks/feel a bit cheap.
leehewitt
Post by leehewitt » Mon Apr 25, 2016 2:20 pm
Thanks IanH755 ill purchase one of these as well to be on the safe side.
IanH755
Post by IanH755 » Mon Apr 25, 2016 3:08 pm
I bought two just to make sure that I could get 100% coverage as I wasn't sure one would be enough.
Just be careful when you fit them, quite a few people have had the paddles jam in the "pulled" position afterwards and you have to strongly push the paddle away from you to free it. It'll keep doing this for a few weeks until the little plastic tang inside the paddles which causes this issue, breaks off. It has no effect on the paddles operation once it's "snapped" so I've no idea what it was there for. Mine did this when I did the CF ones and there's lots of posts on here about the same thing.
Trups
Trader (Expired)
Post by Trups » Mon Apr 25, 2016 3:12 pm
JB Quick weld, will never come off again.
classba
Post by classba » Mon Apr 25, 2016 3:30 pm
Trups wrote:JB Quick weld, will never come off again.
+1 that's what I used... 3m double sided tapes comes off in the summer heat :)
leehewitt
Post by leehewitt » Tue Apr 26, 2016 10:37 am
JB Quick weld it is then - thanks guys.
IanH755
Post by IanH755 » Tue Apr 26, 2016 10:50 am
If I'd used JB Kwik Weld on my current cheap CF paddles, I'd be buggered now I want to change them. I also may decide to change again in the future to a proper CF set (because I like me some CF) so using the foam gives me flexibility to chop and change as I like plus the foam also lasted throughout last summer without coming off.
However, if your confident that once you fit these paddles you'll not want to change them (or replace them if damaged) then Kwik Weld is perfect!
classba
Post by classba » Tue Apr 26, 2016 5:50 pm
IanH755 wrote:If I'd used JB Kwik Weld on my current cheap CF paddles, I'd be buggered now I want to change them. I also may decide to change again in the future to a proper CF set (because I like me some CF) so using the foam gives me flexibility to chop and change as I like plus the foam also lasted throughout last summer without coming off.
Ian, get some proper carbon ones like the one's on Trup's car :)
IanH755
Post by IanH755 » Tue Apr 26, 2016 8:04 pm
I wasn't sure if I like the silver paddle and black CF extenders (odd colour mix), or the silver paddle and the silver extenders (colour match but no CF) or a set of black paddles and CF extenders (need new paddles) so for the time being I'm sticking with the all silver look.
perthwaRS6
Post by perthwaRS6 » Wed Apr 27, 2016 7:41 pm
R33 wrote:Yeah as many have said on here before S2 with a gearbox remap and secondary decat is night and day of a standard car, laugh out loud quick (well it was for me anyway). Last night I gave it a boot with ESP fully off and surprised myself yet again as to how quick it is.
I'm stuck in the where do you go next camp now, so I'm keeping it for a while at least. I just feel that any car I go to now must have at least 700bhp which makes choices very tough and expensive!
Hi R33, :bigwave:
I have to admit, I cant find a sedan that has all the aspects that I like of the RS6. :bowdown: :bowdown: :bowdown:
A keeper for me for sure as my four door sedan :kissmyrings:
cheers,
john
2009 RS6 sedan,5.0L FSI V10,phantom black,730bhp-98 octane,750bhp-104 octane,APR stage 1 map,MTM/Performance Friction 405mm front rotors,JCFabweld sports exhaust,MRC filters,Michelin PSS.
2011 Lamborghini Gallardo LP560-4 coupe,5.2L V10 TT UGR 800-1250whp, e-gear 6 speed,390 mm Alcon Racing front rotors, grey.
1969 E type Jaguar convertible with 5.2L 6 cylinder Rob Beere Racing engine,356 bhp-415 ft-lbs,midnight blue-old school but beautiful
Shinobi675
Post by Shinobi675 » Wed Apr 27, 2016 7:53 pm
What about power to weight? I'd have thought a lighter car with 500bhp would be as quick?
You lot aren't helping my decisions ;) I think it's made and I need to book it in!
Post by bam_bam » Wed Apr 27, 2016 8:16 pm
You've got a piece of Pork, it's a perfect complement to the '6. The only that could flesh out that arrangement more would be a track mosquito - something track-focused, lighter than a bird's fart with about 200-300BHP.
Shinobi675
Post by Shinobi675 » Wed Apr 27, 2016 8:17 pm
Yer that's the issue with the porker, it keeps going up now, so what wouldn't have been too bad two years ago to prank at the ring, is now a bit of a bugger!
perthwaRS6
Post by perthwaRS6 » Wed Apr 27, 2016 8:31 pm
first world problems! :wink:
