After being asked for a prediction, I pitched what I thought was a lowball of 380hp; it was carbon cleaned around 4K ago, has a panel air filter, milltek sort cats and non res system. However it hasn't been mapped.
I'm quite happy with how it drives and seems to pull well.
It posted a mere 349hp.
I got it home and found there to be a vacuum hose leaking quite badly at the power flap valve at the airbox. I've removed this and blanked it. The car feels much better but I'm not sure it's all the way there. Is there anything else I should be looking at?
The sports cats have been on for around 18 moths without a problem but twice in the last month I've had a MIL light and codes for warm up cat efficiency low on both banks 1 and 2 twice and codes for secondary air injection flow low, banks one and two once.
Looking at the dyno print out the torque starts to tail off at 3700rpm and takes a steady decline as the revs build.
The dyno op, whilst not a specialist also wasn't an idiot and suggested a problem with the variable cam timing, is that possible?
I would like to think that there wasn't enough vacuum to hold the flaps fully open, restricting the inlet and reducing the VE is the revs increased.
Any thoughts on where to go from here would be appreciated
