Spacers causes vibration between 60-70 mph?
rs4uk
Post by rs4uk » Fri Apr 08, 2016 7:07 pm
Hi Guys
Just wondered if anyone else who is running spacers gets a vibration from the car like your alloys need balancing?
I didnt have this problem before fitting spacers but seems to happen between 60-70 mph?
Running 10mm on the rear and 8mm on the front
Re: Spacers causes vibration between 60-70 mph?
Post by MikeFish » Fri Apr 08, 2016 7:46 pm
Did you get the right fitment? Where did you buy them from?
Also, check and clean the hub face as well as both sides of the spacer and the wheel face. Any little bit of grit here will cause the wheel to not sit 100% flat and wobble.
Post by MikeFish » Fri Apr 08, 2016 7:47 pm
If that doesn't clear it try swapping wheels / spacers front to rear or remove one set of spacers altogether to narrow down which axle it is at least.
RS4_Ollie
Post by RS4_Ollie » Fri Apr 08, 2016 8:06 pm
Are 8mm wide enough to be hub centric?
Post by MikeFish » Fri Apr 08, 2016 8:16 pm
Yes. Anything over 5mm.
Surrey Sam
Post by Surrey Sam » Fri Apr 08, 2016 8:52 pm
I've had a whisker under 160mph on the clock before with spacers fitted and no vibration at any speed to that point.
R1RS4
Post by R1RS4 » Fri Apr 08, 2016 8:57 pm
Yes as Mike says
Clean up the face of the hubs and also run a large flat file over the wheel mating face, also just to check you have increased your bolt length accordingly?
Good luck
RS4 B7 Avant,2007
Metallic black, Black optics pack, Black gloss Wheels, Milltek black tipped -valved, MRC Installed TTS Supercharger 610ps/626nm, MRC stage 3 remap, CAF, DRC/SS+ with H&R spacers, carbon race splitter, carbon trim
FaisalJ
Post by FaisalJ » Fri Apr 08, 2016 11:15 pm
Rs4uk - just to be sure; the spacers you bought, are they hubcentric?
I've had 8mm, 10mm, 15mm, 20mm and 25mm spacers on my last couple of cars, all hubcentrics, and none of them caused any vibration. I've had the car on track with spacers too - no issues.
The first set of spacers I ever bought though were not hubcentric (before I knew better) and caused lots of vibration.
2007 RS4 B7 Avant
audi_do_dat_den
Post by audi_do_dat_den » Sat Apr 09, 2016 9:52 am
If the hub surface and also the wheel mounting face are not properly cleaned before fitting the spacers, you will get vibration.
If there's rust, a flake of old wheel lacquer or just general <beep> between the spacer and the hub or the spacer and the wheel (or both), the thickness of the spacer will amplify the vibration massively.
As also mentioned, if they're not hubcentric and not from a reputable manufacturer, they might not be perfectly centred on the spigot..... and cause vibration.
rs4uk
Post by rs4uk » Sun Apr 10, 2016 2:28 pm
Hi guys thanks for the replies
The spacers I have are 8mm front forge spacers and 10mm unbranded rear spacers
Now this might sounds like a daft question - hubcentric are the spacers specially designed for the hub?
The vibration im getting is from the steering wheel so will take the spacers off clean up and refit them and see what results i get
What make spacers is everyone else running? H&R seem the popular choice
audi_do_dat_den
Post by audi_do_dat_den » Sun Apr 10, 2016 5:26 pm
I have H&R and theyre a perfect fit on the centre spigot.
I would pay great attention to the surface of the hub and the mounting face of the wheel, even get in there with some decent emery to get every trace of corrosion off the hub and ensure the back of the wheel is nice and smooth.
Even a fraction of a millimetre sized piece of crud or rust will cause wobble when the wheel is spinning at those sorts of speeds.
Post by MikeFish » Sun Apr 10, 2016 6:20 pm
The hubcentric spacers have a lip that sits in the hub to keep the spacer dead centre and stop any vibrations. This is a common issue for non-hubcentric spacers. You may find just removing them and refitting them will make them better / worse depending on how off centre you manage to fit them (if they are not hubcentric).
Most people use the H&R hub centric ones. There are so many variations too, with different size and angle of the hubcentric lips. If you decide to buy any I'd recommend using either Revolution who are site sponsers, or Virdee. Both of these will make sure you have the correct fitment.
rs4uk
Post by rs4uk » Mon Apr 11, 2016 8:20 pm
Hi Mike thanks for explaining the difference between hubcentric spacers and hubcentric - didn't actually know what the difference was
My fronts are not hubcenric so removing them tomorrow and see what difference it makes and hopefully replace them with H&R ones
toyneg
Post by toyneg » Tue Apr 12, 2016 11:04 am
I used to run 8mm hubcentric ones up front but had the same symptoms as you, it is caused by the hub of the wheel not sitting flush enough on the spacer, I couldnt get mine right at all so ended up just running 10mm on the back and now no issues
rs4uk
Post by rs4uk » Tue Apr 12, 2016 4:16 pm
Front spacers removed - non hubcentric 8mm, left the rear spacers on 10mm hubcentric
No vibration at all !!
Users browsing this forum: N9ATH and 120 guests
