C6 upgraded ARB - Is this the right part number
I'm just about to order upgraded H&R Anti Roll Bars for my 2009 RS6
But before I do I just wanted to double check I’ve got the right part number - H&R 33201-1 - Can anyone confirm if that’s the correct Part number?
I've read on here that H&R don’t list the ARB's for the RS6 C6 - the part number I've got is for the Audi A6 Lim.+Avant/ Typ 4F but I understand they fit the RS6. Is this right?
Thanks.
Thanks.
RS6, C6, 2009, MRC Stage 2, Aquamist Water/Meth injection, secondary CAT’s deleted, BMC Filters, Headlight Upgrade second projector with RS lens - Trupps supplied the parts I built myself. Interior LED upgrade, C7 RS gear knob upgrade, AutoTecknic Shift Paddle Extensions, KW V3 Coil-overs, H&R ARB's, H&R spacers 8mm Fr & 10MM R.
On the cards - Primary CAT delete, TTE Turbos
Re: C6 upgraded ARB - Is this the right part number
Rs6Rob wrote:I'm just about to order upgraded H&R Anti Roll Bars for my 2009 RS6
Thanks.
There is an owner on here who recently had them fitted shinobi675 you could ask him to possibly look at his under car to confirm?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
Hope so! They're the ones I ordered last week on eBay.de
Mart.
Mart.
C6 RS6 Plus with a few sensible mods...
I've cross checked the A6 (2009) 4F Quarto OEM ARB against the RS6 (2009) OEM ARB the front is the same (4F0411309E).
The rear is slightly different - Quarto 4F0411309 (J19mm) or (H18mm) or (K19mm)) the RS6 - 4F0411309R 22mm
H&R Specification
Part Number 332011
Fits: Audi A6 Lim +Avant/ Type 4F, 2WD+4WD
Year: 04/04>
Front: VA:32mm Rear: 25mm
Adjustable: 2x Axel: VA+HA
So the H&R & OEM front is 32mm so the H&R should fit no problem.
The rear is 25mm which is 3mm bigger than stock on the RS6 – I can only assume that the bushes have a bigger inside diameter but the same external dimension.
H&R Specification
Part Number 332011
Year: 04/04>
- Shinobi675
- 5th Gear
Phew! I was thinking I'd have to go out with a touch and check!
But... I'm fairly sure MRC mentioned to me a while ago that these are A6 upgrades.
Give me a shout if you want me to check in the morning.
You won't regret these those.
I'm sure I won't...........
Especially as I was able to bag a pair for £122 delivered from Amazon. What a result.........
Do you have an Amazon link to these?
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
bmw e61 m5 saloon
s3 8p stage 2
I got mine from Venom Motorsport
That's great - can you pls share the link to the item on eBay? Are you sure you didn't just buy a front or rear, as they are available separately... That price is less than half price, so I'm assuming you've not bought both front and rear?Rs6Rob wrote:Especially as I was able to bag a pair for £122 delivered from Amazon. What a result.........
Amazon!Ceveman73 wrote:That's great - can you pls share the link to the item on eBay? Are you sure you didn't just buy a front or rear, as they are available separately... That price is less than half price, so I'm assuming you've not bought both front and rear?Rs6Rob wrote:Especially as I was able to bag a pair for £122 delivered from Amazon. What a result.........
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
I was just a very lucky boy, right place right time – and yes it’s for both front and rear, I checked before buying.
But they are considered used but they’re not it's just the packaging has been damaged.
They are normally £281.05 + delivery - http://www.amazon.co.uk/Cars-H-R-HR-332 ... ge_o00_s00
Now there is a downside, I live in Dubai so I’ve got to add shipping from the UK to Dubai and they are heavy 17KG.
So have ended up paying the same total price that you get them for in the UK - but still a result for me.
Is this link for both front and rear?
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2010 Nissan GT-R SVM 680R
Rs6Rob wrote:and yes it’s for both front and rear, I checked before buying.
Oh right, didnt see that.. its £384 on Amazon now, seems expensive?IanH755 wrote:Rs6Rob wrote:and yes it’s for both front and rear, I checked before buying.
i think i can get them for about £260 give or take with exchange rate inc delivery , does anyone know how much of a pain the are to fit i take it subframe out job ?
bmw e61 m5 saloon
s3 8p stage 2
bmw e61 m5 saloon
s3 8p stage 2
