Lowering help - front only!
Re: Lowering help - front only!
The above offer is assuming you have an Avant of course..
Current - 07 Sprint Blue RS4 Avant Black optics / Buckets / FBSW / MRC Stage 2 / De flapped Manifold / CAF / BMC filter / Decat / Non Res Miltek / Bilstein B16's / Tarox discs, pads and lines / H&R ARBs / 19x9.5 Ispiri ISR1 wheels / MPSS tyres / DTM carbon splitter
Previous - 06 Sprint Blue B7 S4 Avant JHM 91 tune / 2.5" Custom Cat-less DP's / Miltek Non Res Cat back / BMC filter / H&R springs / 19" Fox MS007 wheels/Good Year F1's / EBC TG discs / Yellow stuff pads
ASC wrote:The above offer is assuming you have an Avant of course..
If not he can go halves on the KW kit with me haha
I've got a saloon I'm afraid!! Else I would have doneASC wrote:^Genius! Can't believe that was staring me in the face!![]()
So Rw@@dy want to go halves on an H&R spring kit? £90-ish each..
So Rwoodr and Richie both have saloon,s, one wants the front and one wants the rear. Bingo!
I have SS springs on the rear and H&R on the front and it balanced it perfectly for what I wanted. I am running 255/35/20s. Very occasional rubbing if the back is loaded. Mine has 10mm rear and 8mm front H&R spacers.
Not the greatest pics but thats all I have on my phone
Great, thanks for the pics, looks spot on!
kd wrote:I have SS springs on the rear and H&R on the front and it balanced it perfectly for what I wanted. I am running 255/35/20s. Very occasional rubbing if the back is loaded. Mine has 10mm rear and 8mm front H&R spacers.
Is that just SS and not SS+?
Been doing some searching around and everyone else seems to sit quite nice in H+R's!!! Doing my head in now
These are the codes on my rears!!!. Had a look through some google searches and it's a bit inconclusive as to which model they are for!!!
If these are for the avant or cabby then I am up for going halves on some H+R's Rw@@dy
Yes sorryRichieRS wrote:kd wrote:I have SS springs on the rear and H&R on the front and it balanced it perfectly for what I wanted. I am running 255/35/20s. Very occasional rubbing if the back is loaded. Mine has 10mm rear and 8mm front H&R spacers.
Sounds good to meRichieRS wrote:These are the codes on my rears!!!. Had a look through some google searches and it's a bit inconclusive as to which model they are for!!!
If they are for an avant and you guys get a KW kit, I'll buy the H&R's off you Richie?
Part numbers are 29312-2 Saloon & 29312-3 Avant/Cab.
No worries buddyASC wrote:If they are for an avant and you guys get a KW kit, I'll buy the H&R's off you Richie?
As seen in the picture above. there is no sign of a secondary code number i.e. -1 or -2 so I am not sure which springs these are?
Has anyone else got the secondary code marked on their springs?
CoolRw@@dy wrote:Sounds good to meRichieRS wrote:These are the codes on my rears!!!. Had a look through some google searches and it's a bit inconclusive as to which model they are for!!!
Give me a moment just to see what peoples thought are on what I have currently got on the rear at present and if someone can confirm they are the wrong ones then I am in.
TBH I think they must be the wrong ones as no one else's H+R's sit that high on the Saloon!!!!
I found the below from http://www.dcperformance.co.uk/cheap/23 ... 312-1.html I highlighted the part number in red.
Audi A4 Cabrio/Convertible 2WD+4WD H&R Lowering Springs
RRP £231.59
You Save £27.79!
£203.80 inc VAT
FREE DELIVERY!
Details
Audi A4 Cabrio/convertible 2wd+4wd
Type 8H (B6/B7), 1.8T+2.4 l+3.0 l (2WD+Quattro)
Part Number: 29312-1
More information about the H&R lowering springs
Lowers: 30
Spring Marking: Front: VA 29312 VA Rear: HA 29312 HA
RRP £231.59
You Save £27.79!
£203.80 inc VAT
FREE DELIVERY!
Details
Lowers: 30
Users browsing this forum: Bing [Bot] and 385 guests
