Test drove a RS4
2.7 V6 30v biturbo - 380 bhp
Seven
Test drove a RS4
Post by Seven » Tue Jun 28, 2005 9:58 am
I´m on the market for a RS4. Yesterday I test drove a stock 2000 RS4 with 44000Km. What surprised me most, was the rattles from all four doors. I was hopping the build quality to be much better, but that particular car was rattling all the time from the front doors and from the rear lugadge compartment. Clutch pedal was also heavy to operate. Interiors and exterior was in very good shape, but the inside ratlles left me desapointed with this first test. Did I have some bad luck with this specific RS4 , or does an RS4 rattles like an italian car? :roll:
Car didn´t had the 40.000Km done, so it will have to go directly to the shop to do the cam belt service. How much should I expect from a 40.000Km service regardng costs?
How much is the price a a set of four original RS4 wheels? Thanks in advance
RED_ROCKET
RE: Test drove a RS4
Post by RED_ROCKET » Tue Jun 28, 2005 10:37 am
Turn the music up! It helps when im driving..
993 Gt2 - Mid life crisis
RS4 B5 -(Disappeared)
Q7 - Family wagon (RIP)
DaveP
Post by DaveP » Tue Jun 28, 2005 10:40 am
Mine hardly rattles...I suggest taking another one out...
DaveP...
Audi Allroad - Daily slogger
S1 Exige - Track beast
RS4ever
Post by RS4ever » Tue Jun 28, 2005 11:04 am
Creaks perhaps, but not rattles. Silicone on door rubbers makes a big difference.
40K and cam belt change +- £1000
bjacks
Post by bjacks » Tue Jun 28, 2005 11:05 am
I get a few creaks when the car is cold, when warmer the plastics soften a bit and then the noises stop. They are only few and far between though, nothing bad at all.
Wheels probably cost £400 each from the dealer.
Where was the car you drove?
Ben
PhilT
RS246.com
Post by PhilT » Tue Jun 28, 2005 11:25 am
One or two creaks from mine, but defo no rattles - 80000 miles.
Try another one!!
tombs
Post by tombs » Tue Jun 28, 2005 11:32 am
I thought the same on a few I test drove. The one I own now is ok, there sometimes seems to be a bit of commotion from the parcel shelf if its not sitting properly.
As for the clutch, they are heavish all 4 I test drove seemed to be tougher then a normal car and stiffer then my old S4, but you do get used to it.
Seven
Post by Seven » Tue Jun 28, 2005 12:02 pm
tombs wrote:I thought the same on a few I test drove. The one I own now is ok, there sometimes seems to be a bit of commotion from the parcel shelf if its not sitting properly.
The clutch is heavy indeed and not pleasant to operate :( but as you said you really get use to it.
Can the rattles issue be related to year build??? This car is from 2000, maybe cars from 2001 were some how more tight.
The owner didn´t know about the bent wheels issue, he than told me that he had already repaired the wheels twice, but after some time they would bent again. When I drove the car i could felt some shake from the steering, so it´s obvious the wheels are bent. My problem is that if i repair the wheels they will bent in no time again, and a new set of four here costs exactly 3000 euros :shock: ( called delear 5 min ago)
tombs
Post by tombs » Tue Jun 28, 2005 12:24 pm
I would probably steer clear if your that unhappy, IMO there seemed to be no difference between the 2000 & 2001 models when I test drove them. Mines a 2000 and seems fine but it is a lowish milage sample so it may be something to do with that. As for the wheels, the warranty still stands according Audi UK if you have the soft wheels they will replace them but only with the tougher version.
bakerdcb
Post by bakerdcb » Tue Jun 28, 2005 12:48 pm
Creaky leather seats in the back but definitely no rattles from doors. If wheels are bent I guess this isn't going to help. As has been said before, if you're not happy, find another one.
lengster1
Post by lengster1 » Tue Jun 28, 2005 6:02 pm
Creaky shelf but no rattles and clutch is no heavier than a normal car,i would test drive a few more
bobjebb
Post by bobjebb » Tue Jun 28, 2005 6:23 pm
Mine was squealing like mad.
So I asked her to get out and all's well now.
Expect creaks, but have to say the clutch ain't heavy...
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
don
Post by don » Tue Jun 28, 2005 11:26 pm
:lol:
..no rattles on my car.. though rear parcel shelf rattles sometimes when it's pulled out and the left seat if someone has incorrectly adjusted it midway between clicks.
tombs
Post by tombs » Tue Jun 28, 2005 11:33 pm
Sorry, have to disagree on "the clutch aint heavy", I jump from my RS4 to my wife's focus on a regular basis and there is a quiet a difference.
Jani
Post by Jani » Wed Jun 29, 2005 12:45 am
Your wifes Focus has 440 Nm of torque as well then? :)
Clutch is not too heavy IMO, considering the torque it handles. A lot easier than in the RS2 for example. But they do tend to get heavier near the end. But to verify that, you'd need to compare with another RS4.
Doors creak from sealings if they are too dry, silicone is they key as mentioned before.
Users browsing this forum: No registered users and 69 guests
