Gearbox output shaft leaking again... Already.
Re: Gearbox output shaft leaking again... Already.
Post by Shoppinit » Sun Feb 28, 2016 10:28 pm
There is a special Audi tool for pushing in the seal with a shoulder on it. The temptation is to push the tool in until the shoulder hits the flange I guess, but the manual clearly states in big bold letters "do not push the tool all the way to the hilt". Or words to that effect. 1.7mm seems like a very specific number indeed. Must be a reason for it. Another crap design.
I'll make a tool with a shoulder 1.7mm from the pushing surface and see how that goes.
Mav, you are right. It needs to be mentioned in the DIY.
jockthedog
Post by jockthedog » Mon Feb 29, 2016 8:18 am
Is this the Bentley manual for the car or the ZF manual for the box?
The latter mentions nothing other than the tool to use....
Place differential cover 35.150/110 on guide plate 5x46 001 255 and press shaft sealing ring 35.150/120 into the differential cover in the mandrel press, using drift 5x46 001 255.
I did mine after measuring the original position - 3 mm in.
And BTW there was a little lateral play on mine, like you had in that wee video.
Maybe not so much and no sign of any damage inside, but still a litte waggle to it.
Post by Shoppinit » Mon Feb 29, 2016 10:27 am
That sounds like the procedure for the front diff, not the transfer box.
Post by Shoppinit » Mon Feb 29, 2016 10:40 am
This is the tool for the transfer box seal:
https://vw.snapon.com/specialtoolsdetai ... d=33820006
No idea where I would find one, though. Might ask at the Audi dealership later.
Looks like the bolts don't need to be replaced, at least, since I put new ones on last time. Small saving graces...
Post by Shoppinit » Mon Feb 29, 2016 11:02 am
This procedure says to install the seal flush with the housing plate:
Install the new seal flush to the housing. Tap in with a small hammer and seat with a large socket (1.5" or something suitable).
http://www.audipages.com/Tech_Articles/ ... ement.html
/confused.
jockthedog
Post by jockthedog » Mon Feb 29, 2016 12:12 pm
Shoppinit wrote:That sounds like the procedure for the front diff, not the transfer box.
Yeah soz man I was confusing this thread with another.
I'd be confused if I wasn't confused at some point every day :)
Post by Shoppinit » Tue Mar 08, 2016 12:00 pm
Right, bit confused now. Just got the car in the air to replace the seal and it all looks dry as a nun's chuff. No drip from the heat shield.
I pulled the heat shield off and that's mostly dry inside, too.
Now I'm wondering if the drip I saw wasn't oily water from driving in damp conditions immediately before getting it on the inspection ramp, but I could have sworn that it was a beautiful golden pearl of fresh oil hanging from the edge of the heat shield. :bash:
I'm going to let sleeping dogs lie. I will completely clean out the heat shield and get rid of the old oil patch on the garage floor and see if it comes back.
Actually, before that I'm going to check that the box is still full...
Post by chunky79 » Tue Mar 08, 2016 12:52 pm
Shoppinit wrote:Right, bit confused now. Just got the car in the air to replace the seal and it all looks dry as a nun's chuff. No drip from the heat shield.
<beep>
Post by Shoppinit » Tue Mar 08, 2016 12:53 pm
Well, the box is a full as Chunk's mum's after bam and I have paid her a visit. Could not get another drop in without it spilling out.
Post by bam_bam » Tue Mar 08, 2016 1:08 pm
Shoppinit wrote:Could not get another drop in without it spilling out.
Job well done that.
Post by chunky79 » Tue Mar 08, 2016 3:32 pm
Shoppinit wrote:Well, the box is a full as Chunk's mum's after bam and i
Took both of you? Sooo, which one of you is lacking then?
ahoooga
Post by ahoooga » Tue Mar 08, 2016 3:39 pm
:thumb:
Post by bam_bam » Tue Mar 08, 2016 3:48 pm
Well I know I've painted a womb enough to produce two sprogs... how many kids you got, Shop?
jockthedog
Post by jockthedog » Tue Mar 08, 2016 6:43 pm
And of course you can prove they're yours....? :P
Post by chunky79 » Tue Mar 08, 2016 6:57 pm
To be fair, the lad is definitely his, he likes wearing dresses!
* sorry to bring you into it Arlo.
Users browsing this forum: asgor and 82 guests
