Brakes again... B7 RS4
Surrey Sam
Re: Brakes again... B7 RS4
Post by Surrey Sam » Sun Feb 14, 2016 12:10 pm
Galvanic Corrosion under pad retention plates - click image to enlarge
Before spending out and fitting new discs, it's really important to check that your callipers are not exhibiting any form of Galvanic Corrosion under the pad retention plates. If they are, this will be the cause of your discs warping.
As seen in the above picture. The corrosion bubbles up under the pad retention plates and bends them, which in turn causes the brake pads to pinch. The pad surfaces cannot then be evenly applied to the disc surface, causing uneven wear and under high load conditions, overheating. Both a recipe for disc warping.
Lightly brush off the brake dust and if you start to see any white'ish residue around the retention plates, or notice the retention plates are not flat. Then you will need to send the callipers away and get them stripped and refurbished. I warped a brand new set of discs in less than 800 miles by not addressing the corrosion first.
marc1
Post by marc1 » Sun Feb 14, 2016 10:51 pm
^ Great post Sam, thanks for sharing. :beerchug:
colb
Post by colb » Mon Feb 15, 2016 2:22 pm
Collected my front discs from Eurocarparts this morning, right one's from Brembo and £522 for the pair......result! Anyone got any tiea where the best place is for pads now?
daveb77
Post by daveb77 » Mon Feb 15, 2016 8:51 pm
colb wrote:Collected my front discs from Eurocarparts this morning, right one's from Brembo and £522 for the pair......result! Anyone got any tiea where the best place is for pads now?
Good result mate, need to find a code for Europarts now...
Cheers,
D
colb
Post by colb » Mon Feb 15, 2016 9:30 pm
Eurocarparts gives an initial discount then add code LOVEDISCOUNT for a second discount!
daveb77
Post by daveb77 » Mon Feb 15, 2016 10:09 pm
colb wrote:Eurocarparts gives an initial discount then add code LOVEDISCOUNT for a second discount!
superb thanks for that!
D
Surrey Sam
Post by Surrey Sam » Mon Feb 15, 2016 10:20 pm
marc1 wrote:^ Great post Sam, thanks for sharing. :beerchug:
No problem :thumbs:
daveb77
Post by daveb77 » Sun Mar 06, 2016 8:59 am
Just purchased from CP4L with SAVEME75 for £486.18, in stock and free delivery.
Yellow Stuff pads best price next i think...
D
jimster
Post by jimster » Mon Mar 07, 2016 1:43 pm
Are those Brembo discs from CP4L and EuroCarParts the exact same as if buying OEM from Audi?
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 121 guests
