Radio circuit current drain
- 1st Gear
I thought I had a bad battery since my charger never indicated full charge. Figured i should confirm it, and disconnected the battery. After a few hours the charger indicated full charge.
So... I figure I need an amperemeter and start pulling fuses? What's the best method to locate the short?
Edit:
Findings:
The radio circuit is the main drain of 0.68A
I have an aftermarket headunit (Pioneer 3700DAB) that switches off with ignition. It also seems to switch off the amp, as there is a slight pop at turn-on and turn-off.
Edit:
Findings:
2003 RS6 Avant, Daytona grey
2012 Toyota GT86
2014 Toyota Prius Plus 7
2012 Toyota GT86
- Simon the sparky
Re: Draining battery, finding the culprit
To locate a battery drain, disconnect the positive battery terminal, connect a digital amp metre between the battery and the car, make sure everything is turned off and the keys are out, then leave for about 10 minutes. Now check the reading, it should be 0.0, anything more and your search begins.
Pull fuses to find the source of the drain, when you find the correct fuse, disconnect each item protected by that fuse till you find the problem.
If the drain can't be located by pulling fuses, try disconnecting the alternator.
Oh, I forgot to mention, start by disconnecting anything non standard.
Good luck.
Good luck.
Current: RS4 Avant B7, Range Rover 4.4, VW up!, Fiesta ST van.
Previous: A3, S3, A6 Allroad, UR quattro, Porsche 3.2, Skyline R33 GTR,
Subaru WRX,
Subaru WRX,
- Simon the sparky
Sorry, just re read my post, just to make it more clear, the amp metre goes between the positive battery terminal, and the positive lead you have taken off.
Subaru WRX,
Subaru WRX,
You will always have a slight drain due to radio, clock and ecu memories. Each car is slightly different depending on spec. Mine which has RNSE and tracker has a 23 milliamp (0.023) drain after 15 mins. Just remember to flick the boot/ tailgate lock shut so the convenience unit shuts down. Also make sure you have the radio code before disconnecting the battery
- 1st Gear
I have an aftermarket headunit. With the car as it stands I have a 0.68A drain when everything is shut off. Pull the "Radio" fuse and it's down to 0.08. Pulle the telephone fuse too and I'm down to 0.03, which is where I think it should sit. The radio circuit is definetly the bigger drain though. I need to test some more but I don't hava a garage and the snow came in pretty hard, so i'll try again tomorrow with the HU disconnected to see if it's a slow short or the actual HU/amp setup.
2012 Toyota GT86
2012 Toyota GT86
- Simon the sparky
What make is your aftermarket head unit? Has it been wired correctly to turn off when the key is removed, or do you have to turn it off yourself?
If it's a Chinese head unit you've probably found your culprit!
Subaru WRX,
Subaru WRX,
- 1st Gear
It's a Pioneer AVH-X3700DAB unit. It turns off with the ignition, and it sounds like it turns off the amps (BOSE) when it should too (slight pop at turn-on and off).
I still think my battery could be bad though, since 0,6A on a 110Ah battery means it should still be able to start the car after two days..
2012 Toyota GT86
2012 Toyota GT86
- Simon the sparky
You may well have a battery problem, but you will always have starting problems with a 0.6 drain on your battery, this needs to be traced and reduced to no more than 0.05.
Subaru WRX,
Subaru WRX,
Charge your battery off the car till its full ( according to your charger) , leave it till the next day, then put it back on the car and see if it starts it.
Eliminate the battery first rather than chasing around looking for drains
How old is the battery in question ? original one maybe ?
- 1st Gear
@ahoooga: Battery is an original Audi Replacement battery, about two years old.
@Simon: I have found the circuit that has the drain, so at least it's narrowed down slightly.But I'll definitely try your tip to eliminate the battery, thanks!
Last night it had snowed a little and I noticed a small patch of melted snow right in the center of the sunroof (solar panel). So SOMETHING is generating a small amount of heat in that spot. Anyone know what's there?
2012 Toyota GT86
2012 Toyota GT86
- 1st Gear
Re: Radio circuit current drain
So, I'm still at it with this issue.
The Radio circuit is the one with the most current draw of over 0.6A, so that's the obvious place to start. I have an aftermarket headunit and a BOSE adapter to use the built-in amp and speakers. I don't use the CD-changer, nor the navigation system and FM aerials, so I thought I might as well disconnect those to see if one of those units could be the source of the drain.
So, anyone have a diagram over the different units and where they are located? Will the car go nuts if these units go "off the grid"?
Anyone have any comprehensive info/diagrams of the radio circuit and it's different units?
2012 Toyota GT86
2012 Toyota GT86
Users browsing this forum: No registered users and 61 guests
