Hello folks,
Im going to overhaul the front suspension links and bushes etc, but is this possible to do yourself or are there special tools required?
I will change out for a Meyle HD kit in the coming weeks hopefully.
Front suspension overhaul DIY or not?
audi_do_dat_den
audi_do_dat_den
Re: Front suspension overhaul DIY or not?
Hmmm.... i guess thats a 'not' then....
I did mine myself. Hardest part Is getting the old parts off
- esp_mm-270
Not a problem if you can get the upper control arm pinch bolt out. They tend to resist removal
Yep the upper arm pinch bolts are known to seize. I had all upper, lower arms and arb links replaced recently - one side was seized solid and would not shift even using blow torch, ended up with one new upright.
Daytona RS4
Audi Pardner
Agree on the pinch bolts. Mine were a real struggle when I fitted the adjustable spring kit. I doubt they would have come free without a lot of heat, Wurst Rost Off and a 4 post lift. I wouldn't try it at home personally.
Misano Red B7 RS4 Avant. 20" Rotors. KW adjustable spring kit. 8 & 10mm H&R spacers. MRC Stage 2 remap. Pre-cat delete & x-pipe.
Hi all, where are you sourcing your parts from? TPS? I found a complete Meyle HD kit of bushes and arms but never heard of them! :/
2006 RS4
Users browsing this forum: No registered users and 141 guests
