I have an OSF wheel bearing needing replaced, other than Audi Genuine parts which manufacturer would you recommend from these below?
ECP supplied Lucas / Obis £56 each in stock locally
On eBay, SKF £100 a pair
On eBay, generic aftermarket £24.95 each (item 361391094080)
Recommended Wheel Bearing Manufacturer
Re: Recommended Wheel Bearing Manufacturer
I had Lucas from ECP in my C5 (fitted before I bought it), I had no issues but it's only done 20K miles (10k with me and 10k with the guy I sold it too) so it's a bit early to tell how long the life will be but should last 80k+ easily
***NEW*** Daytona C6 RS6 Avant - MRC'd - 955HP & 1200NM (PistonHeads Link)
I like SKF, but I'd probably go with the Lucas ones on ECP.
Lucas is only a brand name that ECP now own. Its a cheap bearing in a branded box.
TBH cheap bearings are ok, they just don't seem to last quite as long as the OE spec ones.
Your choice
Your choice
SKF then.
Cheers, SKF it is...
Users browsing this forum: Majestic-12 [Bot] and 122 guests
