Bluetooth - retrofit. Whine through speakers.
lugars4
Post by lugars4 » Wed Feb 17, 2016 5:54 pm
I retrofitted the bluetooth a while back. Bought the loom off Ebay. All working well.
Sine then, i noticed a whine through the speakers. The pitch increases with the revs of the engine. Its there with the radio on / off, all the time, worse with a cold engine.
So i think its being caused by non-shielded wires on the loom, or a bad earth ? Causing the audio feed to pickup noise from other cables.
Anyone experienced this before?
James
06 - B7 RS4 Saloon - Milltek Non-Res Valved. BMC Filter.
PetrolDave
Re: Bluetooth - retrofit. Whine through speakers.
Post by PetrolDave » Wed Feb 17, 2016 7:45 pm
What Bluetooth module did you fit?
I've helped many people retrofit the OEM BT module and never heard of this problem before.
Surrey Sam
Post by Surrey Sam » Wed Feb 17, 2016 7:51 pm
And how did you wire in the microphone?
lugars4
Post by lugars4 » Thu Feb 18, 2016 3:34 pm
PetrolDave
Post by PetrolDave » Thu Feb 18, 2016 6:02 pm
That's one of the latest OEM modules, so my best guess would be that the harness - which isn't an Audi item as Audi maintain that a BT retrofit is impossible - has been badly made.
As said before I've never heard of this problem with the nearly 50 BT OEM module retrofits I've helped owners with (over 10 of which I've done personally for them).
electricfurnace
Post by electricfurnace » Wed Nov 16, 2016 1:13 am
Did you ever sort this mate as i am having the sane issue!
CaptainLeadFoot
Post by CaptainLeadFoot » Thu Nov 17, 2016 12:40 pm
I have the same issue before and it annoyed me so much I have to take it out. I think the wiring needs additional shielding as the centre console has a lot of interference. Good if you can add extra earthing wires.
electricfurnace
Post by electricfurnace » Fri Nov 18, 2016 12:57 pm
CaptainLeadFoot wrote:I have the same issue before and it annoyed me so much I have to take it out. I think the wiring needs additional shielding as the centre console has a lot of interference. Good if you can add extra earthing wires.
Was that with a genuine Audi bluetooth box mate?
I am going to try a new harness from Kuftatech to see if that solves. Not holding my breath though.
Where would I add extra earthing wires and where from?
CaptainLeadFoot
Post by CaptainLeadFoot » Sat Nov 19, 2016 7:40 am
I have the kauftec fiscon module, the OE one won't work as aftermarket fitting I believe the wiring harness is not compatible. The OE one is supposed to be hidden under the passenger's seat.
You need to find the head unit's ground and put an extra grounding to the metal part of the chasis.
Running the wire perpendicular to the antenna is supposed to minimize the interference also.
Here's an article that could also help:
http://www.popularmechanics.com/cars/ho ... 4/1272491/
I think the biggest reason is not the noise for me, but the music is only stream as mono to the speakers thatis not what I wanted. It's perfectly ok for phone calls though. I ended up buying a FM transmitter instead for the music.
electricfurnace
Post by electricfurnace » Sat Nov 19, 2016 12:24 pm
Head unit ground to metal part of chassis-
Do you mean ground it to the metal chasis of the head unit itself or to the car?
Finding head unit ground - do you mean splice off the ground on the loom rather than internally in the head unit?
CaptainLeadFoot
Post by CaptainLeadFoot » Sat Nov 19, 2016 5:55 pm
ground the wiring to the chasis. you need to attach an extra wire of the same gauge to do the grounding.
don't ground to the mounting bracket of the head unit unless you test and it is actually connected to the chasis, sometimes it could be just a piece of metal between plastics, or a factory grounding point.
electricfurnace
Post by electricfurnace » Tue Nov 22, 2016 10:03 pm
Given up on this <beep> thing, even a kufatec harness still whined.
Time to consider other options
MB2
Post by MB2 » Tue Nov 22, 2016 10:24 pm
Where have you installed the BT module ? Audi put in the passenger footwell and most retrofits go behind (under) then glovebox - if yours was nearer the RNS-E mayvbe that is the problem ?
I have also seen roofing lead used to shield electronic clocks from interference but I would get the two items as far away from each other as possible and test again.
electricfurnace
Post by electricfurnace » Tue Nov 22, 2016 10:36 pm
Bt module is behind glovebox. Mic lead runs up side pillar and along into the light cluster in the middle.
Have also plugged bluetooth ina and left it on passenger floor, still the same.
Stereo works fine, as soon as i plug in the bluetooth harness theres inteferenceand noise, mainly from the rear speakers, oddly.
Users browsing this forum: Google [Bot] and 80 guests
