Brakes again... B7 RS4
- Surrey Sam
Re: Brakes again... B7 RS4
As seen in the above picture. The corrosion bubbles up under the pad retention plates and bends them, which in turn causes the brake pads to pinch. The pad surfaces cannot then be evenly applied to the disc surface, causing uneven wear and under high load conditions, overheating. Both a recipe for disc warping.
Lightly brush off the brake dust and if you start to see any white'ish residue around the retention plates, or notice the retention plates are not flat. Then you will need to send the callipers away and get them stripped and refurbished. I warped a brand new set of discs in less than 800 miles by not addressing the corrosion first.
^ Great post Sam, thanks for sharing.
Collected my front discs from Eurocarparts this morning, right one's from Brembo and £522 for the pair......result! Anyone got any tiea where the best place is for pads now?
Good result mate, need to find a code for Europarts now...colb wrote:Collected my front discs from Eurocarparts this morning, right one's from Brembo and £522 for the pair......result! Anyone got any tiea where the best place is for pads now?
Cheers,
D
Eurocarparts gives an initial discount then add code LOVEDISCOUNT for a second discount!
superb thanks for that!colb wrote:Eurocarparts gives an initial discount then add code LOVEDISCOUNT for a second discount!
D
- Surrey Sam
marc1 wrote:^ Great post Sam, thanks for sharing.
No problem
Just purchased from CP4L with SAVEME75 for £486.18, in stock and free delivery.
Yellow Stuff pads best price next i think...
D
D
Are those Brembo discs from CP4L and EuroCarParts the exact same as if buying OEM from Audi?
Users browsing this forum: Google Adsense [Bot] and 98 guests
