c7 discs fit?
5.0 V10 50v biturbo - 571 bhp
marknjayne
c7 discs fit?
Post by marknjayne » Fri Feb 12, 2016 6:16 pm
Hi ,do the C7 discs fit the C6?
IanH755
Re: c7 discs fit?
Post by IanH755 » Fri Feb 12, 2016 7:07 pm
Short answer - No, they are not a direct fit but you could mod them to fit.
Info taken from another I put this in -
Fronts - The Hat Height is different
C6 - 59.5mm
C7 - 53.5mm
So you'd have to fit 6mm spacers to the calipers to fit the C7 discs.
Rears - I've not got any info for C7 rear Disc height but C6 is 42.5mm ***however*** the C7 discs are 22mm thick vs 28mm for the C6.
marknjayne
Re: c7 discs fit?
Post by marknjayne » Fri Feb 12, 2016 7:17 pm
IanH755 wrote:Short answer - No, they are not a direct fit but you could mod them to fit.
C6 - 59.5mm
C7 - 53.5mm
Cheers Ian,im not adding spacers so i will just have to get the C6 discs,just love the look of the C7 discs and they are cheaper,OEM Audi best?
IanH755
Re: c7 discs fit?
Post by IanH755 » Fri Feb 12, 2016 7:23 pm
No be honest I found the OEM discs/pads to be "good enough" only for normal driving with the odd short B-road blast but I found the 2-Piece AP Racing setup (£800 so virtually same price as C6 OEM) to be much better and they could cope with everything I've done so far inc a trackday. I also found that the Ferodo DS2500 pads were much better than stock too and were, again about OEM price unsurprisingly :D
One advantage of the AP setup is that, once you've bought them, when it come time to replace the rotors it's only £600 for a set so even cheaper than OEM.
marknjayne
Re: c7 discs fit?
Post by marknjayne » Fri Feb 12, 2016 8:19 pm
IanH755 wrote:No be honest I found the OEM discs/pads to be "good enough" only for normal driving with the odd short B-road blast but I found the 2-Piece AP Racing setup (£800 so virtually same price as C6 OEM) to be much better and they could cope with everything I've done so far inc a trackday. I also found that the Ferodo DS2500 pads were much better than stock too and were, again about OEM price unsurprisingly :D
excellent AP it is then ,where did you buy yours from
IanH755
Re: c7 discs fit?
Post by IanH755 » Fri Feb 12, 2016 9:12 pm
Here's who I used and they arrived the next day! -
They can also supply Ferodo DS2500 pads (no wear sensor) pt no FRP3133H for £240
Hi Ian
The discs are £294.80 each and the bells are £99.70 each both prices include VAT.
Kind regards
Ewen MacRae
Clark Motorsport Ltd
Aquherton Business Unit
Kintore, Inverurie
Aberdeenshire
AB51 0XH
01330 860999 (Office)
01330 860111 (Fax)
ewen@clarkmotorsport.co.uk
http://www.clarkmotorsport.co.uk
You need these part numbers -
2x CP8080Z240 - Bells
1x CP8080Z24CG12 - Right Disc
1x CP8080Z25CG12 - Left Disc
The bells need fitting to the discs (all parts supplied) and you need a 6NM Torque wrench & an E12 Star Socket (maybe E10) but its very simple and only takes about 15 minutes per disc.
marknjayne
Re: c7 discs fit?
Post by marknjayne » Fri Feb 12, 2016 9:20 pm
Excellent thank you Ian
JDL
Re: c7 discs fit?
Post by JDL » Thu Feb 25, 2016 7:03 pm
If anyone interested we have in stock DS2500 pads for RS6 C6 for £180 shipped.
http://www.jdl-brakes.com/ferodo-ds2500 ... 3133h.html
993turbo
Re: c7 discs fit?
Post by 993turbo » Fri Mar 11, 2016 11:52 am
Have had C7 discs on for nearly 2 years now...
RS6 MTM C6 Avant (Daily Driver)
360 Modena (manual)
F430 Spider (F1)
+ 4 classic Porsches
marknjayne
Re: c7 discs fit?
Post by marknjayne » Fri Mar 11, 2016 5:09 pm
993turbo wrote:Have had C7 discs on for nearly 2 years now...
really,any pics ,straight fit or modifications required ?
993turbo
Re: c7 discs fit?
Post by 993turbo » Mon Mar 14, 2016 9:57 pm
front 6mm ''spacers'' on the calipper mounts.
rears nothing. Just dont run the pads too low as the discs are thinner.
360 Modena (manual)
F430 Spider (F1)
rs6_sid
Re: c7 discs fit?
Post by rs6_sid » Mon Mar 14, 2016 10:59 pm
So you space out the bolt with a 6mm washer if you will, interesting to know as they are cheaper than c6 items !
c6 rs6 avant- mrc stage 2 -current
bmw e61 m5 saloon
s3 8p stage 2
vw bora tdi hybrid turbo
993turbo
Re: c7 discs fit?
Post by 993turbo » Tue Mar 15, 2016 10:11 pm
Well, you dont space out the bolt. You space out the calipper mounting to center the calipper on the the discs. The C7 discs have a 6mm diffrent offset.
360 Modena (manual)
F430 Spider (F1)
TomRS
Re: c7 discs fit?
Post by TomRS » Wed Mar 16, 2016 11:04 am
Basically where the bolt goes through the calliper mounting bracket on the hub you put a longer bolt and a 6mm spacer this move the calliper further out to take up the offset of the difference in the bell (i had to use 10mm titanium spacers when i ran my Tarox 16's)
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten :smile_smoking:
2010 Nissan GT-R SVM 680R
IanH755
Re: c7 discs fit?
Post by IanH755 » Wed Mar 16, 2016 11:33 am
Just remember to use longer bolts as the stock ones will have 6mm less thread available once you add a spacer which may not be enough for a secure fit!
