Potential issue with coolant hose rupture (Facelift RS6)
Leo-RS
Re: Potential issue with coolant hose rupture (Facelift RS6)
Post by Leo-RS » Wed Feb 10, 2016 11:04 am
NLM13 wrote:Just checked my car after reading this thread, and the clip was only a few mm's in from the edge of the heat shield. There is a mark on the hose where it has rubbed, but thankfully not too bad as yet. As my car is now 18 months old, it would appear that this is not just an issue with FL models. I must just drive it too sedately to have caused so little damage :D
Interesting, do you have the matrix headlights by any chance? Optional extra? They are standard on all facelift cars but optional on the pre facelift cars. Wondering if the engine is mounted slightly differently for the additional/changed hardware.
MY16 Audi RS6
NLM13
Post by NLM13 » Wed Feb 10, 2016 2:48 pm
Yes, I do have the matrix lights. Wonder if that is a factor?
Leo-RS
Post by Leo-RS » Wed Feb 10, 2016 3:36 pm
NLM13 wrote:Yes, I do have the matrix lights. Wonder if that is a factor?
The issue appears to be on all facelift cars and only some pre facelift cars from what I can gather. All facelift cars have the matrix lights, some pre facelift cars have optional matrix lights. Quite possible I suppose, perhaps the engines are mounted slightly differently for clearance. Strange one.
MY16 Audi RS6
Zeebuilder
Post by Zeebuilder » Wed Feb 10, 2016 3:44 pm
I have a facelift car and when I went out this morning the clip was a good 15-20mm from the hose.
It looked like it had been rubbing but further investigation showed that the markings were white paint probably used in quality control in the factory to mark that the hose clip was present and fitted correct.
I tried to move it anyway and was stuck solid but easy enough to bend out of harms way.
CH3OH
Post by CH3OH » Fri Feb 12, 2016 2:55 pm
Before
After
Needmorespace
Post by Needmorespace » Thu Mar 17, 2016 11:09 pm
Can't find any sign of the clips or the metal cover near the hose through the firewall. I wonder if Audi removed this when it was back for other work. See photos, am I missing something?
Needmorespace
Post by Needmorespace » Thu Mar 17, 2016 11:11 pm
Post by MikeFish » Mon Oct 17, 2016 9:02 pm
Just bumping this thread for all the new owners that might have not seen it 1st time around.
wrekka
Post by wrekka » Mon Oct 17, 2016 9:24 pm
Cheers Mike
I will have a look on mine
TTS RS4 -amazing machine,
Previous:
rtd
Post by rtd » Thu Oct 20, 2016 12:26 pm
MikeFish wrote:Just bumping this thread for all the new owners that might have not seen it 1st time around.
its for things like this that make a forum. :jump_clap:
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
Nigelo2
Post by Nigelo2 » Thu Oct 20, 2016 6:26 pm
My MY2016 (March/April build) has a clearance of 1cm.
Nitro_jav
Post by Nitro_jav » Thu Jun 15, 2017 3:44 am
I have a rs6 c7.5, 10kmiles, today i was driving and when i floored it i seen alot of smoke in the rear view mirror so I immediately pulled into a side street and then discovered coolant leaking underneath.
Ps please check this imagine your on the motorway or far from home.
Audi should recall and sort this problem out. Only had the car for 3 weeks.
I will update what audi or the garage find and say.
bn8959
Post by bn8959 » Thu Jun 15, 2017 8:56 am
Thanks for bumping this. Just checked mine ('16 FL) and there was about 15mm of clearance, so seems ok to me.
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
Tadass910
Post by Tadass910 » Thu Jun 15, 2017 10:06 pm
Fail Audi, it's not professional if such things happen
TRS6
Post by TRS6 » Fri Jun 16, 2017 12:47 am
Apologies for amateur hour over here...
But could someone post a better picture and arrow specific to the part I should be looking at adjusting?
Can't make out exactly on mine where/what I should be looking at.
Hoping someone could help this oxy moron here.
Current Cars:
2018 991.2 GT3 - Carrara White
2010 997.2 GT3 - Carrara White (Sold)
1982 911 Carrera RSR IROC - White
2016 RS6 PE - Nardo Grey
2016 Audi A1 S-Line - White
