Help!!!!!!!!!!
Chuds1
Help!!!!!!!!!!
Post by Chuds1 » Thu Jan 21, 2016 9:49 pm
Hi All,
So I decided after having my car since I bought it in October there I would like to get it on the rollers to see what power it was putting out. Just for my own piece of mind. So I got the car booked in and it went on the rollers this morning.
To say I got a shock was an understatement. After the first 4 consistent runs it returned a result of 264.2 HP at the fly wheel. Holy :dung: are you kidding me on is that all....
After some trouble shooting there was a vacuum leak detected at the air box intake valve. This was sorted and then another 4 consistent runs were carried out. This time returning the reading of 291.3 HP at the fly wheel.
Very disappointed as I was hoping it would have been running around the mid 300's.
I'm looking for some advise on to why it is so down on power. I have read a bit about the carbon build up on the intake manifold and that it helps to have it cleaned. But is it normal seeing a reading as low as 291.3 HP?
Thanks for all your help.
RS4 B7 Saloon Sprint Blue, Bilstein B14 Coilovers, Milltek Cat Back resonated non valved. Spacers 8mm F and 10mm R. Headlight clear zenon lens upgrade with 5500k bulbs plus indicator orange lens delete.
Covkiller
Re: Help!!!!!!!!!!
Post by Covkiller » Thu Jan 21, 2016 10:37 pm
Get booked into MRC, they'll fix it.
Alright, alight, everything's gonna be alright :thumbs:
mikep99
Re: Help!!!!!!!!!!
Post by mikep99 » Thu Jan 21, 2016 10:53 pm
Might be worthwhile getting it on the dyno somewhere else just to compare.
Also, have you driven other rs4s to get a feel how quick they should be and is yours any different?
I'm interested as I've done none of the above and mine seems to do the 3rd gear test about right.
Mike
Lukes3
Re: Help!!!!!!!!!!
Post by Lukes3 » Thu Jan 21, 2016 10:58 pm
Plus 1 with booking it in at mrc. If your also not very hands on defo get it booked at mrc so they sort it.
S4Player
Re: Help!!!!!!!!!!
Post by S4Player » Thu Jan 21, 2016 11:06 pm
I put my old supercharged b7 on one those dyno's. Dyno'd 640 at Mrc and 480 on the other rollers. If Mrc are handy enough I'd give them a visit
Chuds1
Re: Help!!!!!!!!!!
Post by Chuds1 » Thu Jan 21, 2016 11:36 pm
Covkiller wrote:Get booked into MRC, they'll fix it.
Thanks Covkiller I've heard there the ones to check out. Miles away though.
Chuds1
Re: Help!!!!!!!!!!
Post by Chuds1 » Thu Jan 21, 2016 11:39 pm
mikep99 wrote:Might be worthwhile getting it on the dyno somewhere else just to compare.
Mike
Good idea Mike to get a comparison done, although you would expect the readings to be accurate.
I've never driven another RS4 so I can't compare. What do you mean by the 3rd gear test?
Chuds1
Re: Help!!!!!!!!!!
Post by Chuds1 » Thu Jan 21, 2016 11:45 pm
S4Player wrote:I put my old supercharged b7 on one those dyno's. Dyno'd 640 at Mrc and 480 on the other rollers. If Mrc are handy enough I'd give them a visit Image
Wow 160 of a difference that is unbelievable. Might try a comparison run somewhere else then before I take the plunge and head to MRC.
Re: Help!!!!!!!!!!
Post by MikeFish » Thu Jan 21, 2016 11:54 pm
If you have VCDS and a laptop or a Bluetooth OBD dongle and a smartphone / tablet you could log some mass air flow readings which will tell you if you are really down on power or had a bad dyno.
Harris.
Re: Help!!!!!!!!!!
Post by Harris. » Fri Jan 22, 2016 12:03 am
Where abouts are you located ? maybe worth also meeting up with some one from here if anyone is near by to compare . These old tanks are getting
on now and need some love !!
Chuds1
Re: Help!!!!!!!!!!
Post by Chuds1 » Fri Jan 22, 2016 12:26 am
MikeFish wrote:If you have VCDS and a laptop or a Bluetooth OBD dongle and a smartphone / tablet you could log some mass air flow readings which will tell you if you are really down on power or had a bad dyno.
I'm probably better leaving that department to the experts Mike.
Harris. wrote:Where abouts are you located ? maybe worth also meeting up with some one from here if anyone is near by to compare . These old tanks are getting
I'm located in Kilmarnock, would be great to compare. Agreed about needing some love, really want to get the best out the car or there's no point having it. :biggrin3:
Chuds1
Re: Help!!!!!!!!!!
Post by Chuds1 » Fri Jan 22, 2016 12:28 am
Anyone recommend a reliable rolling road near to where i am to have a comparison done.
S4Player
Re: Help!!!!!!!!!!
Post by S4Player » Fri Jan 22, 2016 12:39 am
Chuds1 wrote:Anyone recommend a reliable rolling road near to where i am to have a comparison done.
I'm based in Glasgow, you never went to hypertech for your dyno run did you?
Chuds1
Re: Help!!!!!!!!!!
Post by Chuds1 » Fri Jan 22, 2016 12:50 am
No I went to Andy Gallacher Motorsport, Moorfield Motors.
S4Player
Re: Help!!!!!!!!!!
Post by S4Player » Fri Jan 22, 2016 12:53 am
Yeh I know andy from his old focus days. I never used anyone up here i always went down to Mrc. The ecotune dyno in Hillington seems to read well maybe give them a shot. There's a few Edinburgh lads on here who should be able to offer alternatives for you. If I can find my old Vagcom cable I'd be happy to help you run some checks. I know the b7 pretty well
Users browsing this forum: No registered users and 353 guests
