Coilovers , arch rolling advice
Re: Coilovers , arch rolling advice
I had the KW springs fitted just before xmas and i was getting rubbing everytime i went over small bumps. First thing i did was get the wheels off and remove the screw at the top of the arch liner, this seems to have cured the rubbing. I have 8mm spacers on the front with Eagle F1's.
Ok ok ok ok found it and all those that said front wheel arch screws were right, polished including the plastic washer blocks
I could swear it was the rears, including my endless passengers agreed.... Well it's sorted, took out today after removing the screws, did endless speed humps - wow loving it.
RS4 B7 Avant,2007
good to hear things are resolved!!R1RS4 wrote:Ok ok ok ok found it and all those that said front wheel arch screws were right, polished including the plastic washer blocks
I could swear it was the rears, including my endless passengers agreed.... Well it's sorted, took out today after removing the screws, did endless speed humps - wow loving it.![]()
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
Car goes in tomorrow for a complete clutch, they are going to check the DRC pressure tooRS4eddie wrote:good to hear things are resolved!!R1RS4 wrote:Ok ok ok ok found it and all those that said front wheel arch screws were right, polished including the plastic washer blocks
RS4 B7 Avant,2007
Good job! It's nice when you sort out those niggly little probelms! Especially when they are easy to fix eventually.
