Coilovers , arch rolling advice
R1RS4
Re: Coilovers , arch rolling advice
Post by R1RS4 » Tue Jan 12, 2016 7:58 pm
RS4eddie wrote:
R1RS4 wrote:Nice piece of kit - simples
What did you do with the rear inner arches?
rears were fine..not needed. are you running in the back too??
Yes mine is rubbing at the back both sides, standard 19's, recently removed the 10mm spacers but still rubs, so putting it up on ramp tomorrow see if I can find the reason
Just interested on how the arch rolling was done, as I would like to move to 20"s and go as wide as poss, could probably make that kit myself if I couldn't hire it
RS4 B7 Avant,2007
RS4eddie
Post by RS4eddie » Tue Jan 12, 2016 8:04 pm
Strange your rubbing in the rears.. I had 12mm spacers with stock wheels/tires and did not rub.
what size tires?
You can purchase Fender Rollers if you think you trust yourself doing the job:
http://www.eastwood.com/fender-roller-c ... fgodkA8BCg
2007 RS4 | Phantom Black | Milltek'ed | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | K&N Filtered | Ziza lit | Lamix-ed | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded
R1RS4
Post by R1RS4 » Tue Jan 12, 2016 8:18 pm
Goodyear Eagle F1's AS2's. 255x35x19
They are known to be very square, or wider with the rim protector's
Nice piece of kit and a good price :biggrin3: :blackrs4:
RS4 B7 Avant,2007
DavidRS4
Post by DavidRS4 » Tue Jan 12, 2016 8:23 pm
R1RS4 wrote:Yes thx Mike for the link
Dave, Love the set up
How did they finish the arches edges off? Did they fold the lip back inside?
Do love that RS6 grill, what have you done about the number plate? Rich
Thanks. The inner lip that goes in on the front arch was completely removed and then finished properly as if it was never there in the first place. Definitely not folded back up inside. Very crude way that in my opinion.
I cut two diamond shapes to mount behind the plate in the screws. They then slot through the grill and get turned 90 degrees to lock in place. There's foam padding on the back of the number plate so it doesn't rub.
R1RS4
Post by R1RS4 » Tue Jan 12, 2016 8:33 pm
Cheers for the reply
Pro job then,
Which model RS6 grill is that then? I have seen some cars running without the front number plate, the guy from QST runs his RS5 without a plate does look good, but my luck I would be stopped every day
RS4 B7 Avant,2007
Post by MikeFish » Tue Jan 12, 2016 9:17 pm
Are you still rubbing after having the DRC presures checked? It should not rub with OEM wheels and standard tyre size even if Eagle F1s.
FaisalJ
Post by FaisalJ » Tue Jan 12, 2016 9:30 pm
Isn't there a screw for the arch liner that causes rubbing, that can just be removed? Should be easy to spot, will probably have a very shiny and polished up head!
2007 RS4 B7 Avant
Post by MikeFish » Tue Jan 12, 2016 9:32 pm
Only on the front, not the rears.
R1RS4
Post by R1RS4 » Tue Jan 12, 2016 10:00 pm
MikeFish wrote:Only on the front, not the rears.
No Mike,
Car goes in on the 20th for the clutch change
Spoke to them today re checking the pressure, guy said he can do that without losing pressure, but he thinks more Spring related, so going to get the car raised on ramps tomorrow and have a good look, it only happens on the rear, both sides from wheel to arch are equal
RS4 B7 Avant,2007
R1RS4
Post by R1RS4 » Wed Jan 13, 2016 3:01 pm
Had a look under it today, springs are fine, well not broken, cannot see any rubbing in the wheel arches, no play in the shocks, so unless it's well down on DRC pressure, but the car does not bounce about, does sound like a rotational rub
Will have to wait till the 20th now
Did get all 4 wheels balanced and weights moved to the inside edge, got rid of the "white" weights off the fronts, that some reputable tyre fitters fitted, yes on black gloss wheels
RS4 B7 Avant,2007
Post by MikeFish » Wed Jan 13, 2016 3:15 pm
Have you checked alignment? Might need a little more camber on the rear to bring the top in slightly?
R1RS4
Post by R1RS4 » Wed Jan 13, 2016 6:52 pm
MikeFish wrote:Have you checked alignment? Might need a little more camber on the rear to bring the top in slightly?
Thing is Mike I had a very bright torch up in the arches and there no rubbing marks at all, the car was right up in the air on a hydraulic lift, 2 of us were under there for about 1/2 hour, just could not see anything that's rubbing or loose so totally baffled at the mo
RS4 B7 Avant,2007
Covkiller
Post by Covkiller » Wed Jan 13, 2016 8:12 pm
You will find that rolling is a complete waste of time and cracked paint. I know from experience. The only way to go is get a decent body Shop to flatten and spray them up.
RS4eddie
Post by RS4eddie » Wed Jan 13, 2016 9:53 pm
Covkiller wrote:You will find that rolling is a complete waste of time and cracked paint. I know from experience. The only way to go is get a decent body shop to flatten and spray them up.
if your roller knows what he's doing, you will have zero problems.
iduff
Post by iduff » Thu Jan 14, 2016 3:56 am
How does one check the DRC pressure?
B7 RS4 Sedan, Phantom Black Pearl
Valved non-resonated Milltek with 200-cell DPs, and JHM tune, 10mm spacers
B8.5 Allroad, Monsoon Grey
CPO, stock
Former Quattros
B5 S4 Sedan, C4 S6 Avant, Type 89 Coupe Quattro, Type 44 Quattro Sedan
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 53 guests
