Hi guys...
I'm just looking to double check that the RS has the wind back rears, and is there anything 'special' about them I need to know, like do I need to use VCDS somehow with them?!?
Since I got mine back out of storage, the left rear is sticking quite badly, so I need to sort it out.
cheers!!
Wind back rear caliper
Re: Wind back rear caliper
Yes, No, No, I think.
C5 has cables, not motors. No VCDS required. Most windback tools will be for 38mm pistons, these have a 43mm piston and I had to use a lathe to make the tool seat properly around the piston.
I just bought this
https://www.machinemart.co.uk/p/laser-5 ... Ajxy8P8HAQ
That worked on the back of my C6, and I'm sure its the same caliper just with EPB instead of cables (but don't know for sure)
Audi RS4 B5 + Audi Q7 4.2TDi
Gone but not forgotten
2017 Mercedes E63S W213 1033/1400nm
2013 Mercedes E63S W212 740/1200nm
2010 Nissan GT-R SVM 680R
2010 RS6 C6 Avant Stage 2 730/1088nm
thanks
TomRS wrote:I just bought this
C5 has 22mm thick discs and C6 has 28mm, otherwise yes they seem to be identical in design.
Although there are only 2 holes in C5 pistons and they are at 180 degrees apart, that 3pin one doesn't seem like a good choice.
Users browsing this forum: Majestic-12 [Bot] and 61 guests
