Gearbox Limp Mode
nai
Gearbox Limp Mode
Post by nai » Tue Jan 12, 2016 10:18 am
Hi All,
I have a C5 RS6 2003
Have had this issue for a few weeks now i will explain the best I can because it really is a strange one...
If i start the car with one motion of the key all is well...
If i turn the key to position 2 (All lights on, engine off) then start the car... the gearbox will go into limp mode (all PRNDS lit up)
if i switch the car off and back on all is well.
Have changed the oil and filter.. initially it was 2 liters down but have corrected this now.
Also have changed the battery for an original Audi one.
Checked all plugs to and from gearbox
Checked all wiring to all solenoids and the wiring loom.
fault code comes up with 18243 Control valve 5 (N223) short to plus.
Re: Gearbox Limp Mode
Post by Shoppinit » Tue Jan 12, 2016 11:07 am
Didn't you already post a topic about this?
nai
Post by nai » Tue Jan 12, 2016 11:25 am
i did but now its doing different things
Post by Shoppinit » Tue Jan 12, 2016 1:24 pm
Shoppinit wrote:Sounds like it's a poor connection on the loom connector. Higher battery voltage can allow more current to flow through the poor connection masking the problem somewhat. Possibly.
You could try cleaning the contacts, but that doesn't always help and you may need a new set of connectors.
nai
Post by nai » Tue Jan 12, 2016 1:41 pm
Would this be the loom connected to the solenoids? I pulled them all out checked the whole look looks like a new loom ... however thinking about it
my drive way has alot of mud, when i check the multi plug which goes on the gearbox pan it had mud all around it. i did clean it but didn't seem to make a difference but wasn't a proper clean as i could not see inside the pins.
Post by Shoppinit » Tue Jan 12, 2016 1:46 pm
nai wrote:when i check the multi plug which goes on the gearbox pan it had mud all around it. i did clean it but didn't seem to make a difference but wasn't a proper clean as i could not see inside the pins.
I would start by eliminating this. Make sure the connections are perfect.
If it's not that then I would trace back and maybe double up the earthing points temporarily to check that it's not a poor earth.
nai
Post by nai » Tue Jan 12, 2016 3:00 pm
ok will need to get under there at some point.... have a feeling its a connection issue............
Also just to make sure... how much gear oil does the gearbox pan hold? and how much does the total gearbox hold?
thanks
Post by Shoppinit » Tue Jan 12, 2016 3:08 pm
If you need to replace the ATF then you'll need about 7 litres. Also there is a specific procedure you need to read up on. It's not a simple top up procedure.
nai
Post by nai » Tue Jan 12, 2016 4:49 pm
sure, i had a big read up on this as i know its not an easy task.
Users browsing this forum: asgor, Google [Bot], srichards and 114 guests
